Question about Lands Phones
How can I change the ring back time for a call on hold? My phone currently only keeps a call on hold for 30 seconds before it starts ringing back. Drives me CRAZY.
My phone currently only keeps a call on hold for 30 seconds before it starts ringing back. Drives me CRAZY. I would like the ring back time to be 1 to 2 minutes.
Posted by Andrea H on
Rogel Donn
    New Friend:
    Problem Solver:
  • 11 Answers
Try to check ur call settings. look for hold durations
Posted on Dec 08, 2015
How do I extend the ring for an incoming call
Extending your ringing tone You can change the length of your ringing tone by typing the below code into your phone.
**61*(mailbox number)**(number of seconds you want it to ring for)# send You can choose between 5 and 30 seconds. The standard ringing time is 15 seconds.
If you don't know your mailbox number it's just your normal mobile number with '5' added after the prefix. For example, 087 5 1234567.
Apr 12, 2015 | Cell Phones
I would like to change the ring numbers on my Panasonic KX T 7730 from two to four or five because sometimes it's impposible to get to the phone that fast
You need to enter the programming mode from the default EXTN usually 20 or 21 and change the timings of the ring counts, normally shown in seconds, adjust to 30 secs which should give you the amount of rings you need if not just go back and adjust the ringing counter seconds up until you find the length of time that suits your needs.
Aug 31, 2013 | Panasonic KX-T7730 Corded Phone
How do i change the number of rings before voicemail picks up on a samsung rugby
For all of you that want a real answer here ya go. This isn't something you can change on your phone this has to be changed with your service provider. If you are with AT&T, like I am, then this is the solution for you (link of where I found it below as well). 1. enter *#61*11# and press send/talk on your phone.
2. write down the number your calls are currently forwarded to (usually +1401#######, but not always). this is your voicemail deposit number.
3. decide how long you want the phone to ring in 5 second intervals. the maximum time is 30 seconds. i'd recommend 25 seconds or less, as using 30 may cause you to be billed for a minute of airtime each time someone is forwarded to voicemail.
4. now enter **61*[number from step 2]*11*[number from step 3, use 2 digits]# and press send/talk.
example
voicemail deposit number is +14015551212
you want it to ring for 20 seconds
you would enter **61*+14015551212*11*20# and press send/talk.
if you have trouble with the above procedure, you can always call customer care at 800-331-0500 to change it.
OR QUESTION: How can I adjust the number of times my wireless phone will ring before the caller goes to voicemail? ANSWER: Contact Customer Care at 1-800-331-0500 or dial 611 from your wireless phone to change the amount of time your phone will ring before going to voice mail. The adjustments made by Customer Care are based on the traditional ring heard by the caller, not the unique Ringtone you hear from your phone. I just wanted to add that increasing the ring length to 30 seconds will not cause you to be charged a minute should the caller go to voicemail. This was confirmed by an AT&T technician.
http://forums.att.com/t5/Voice-Mail/Increase-the-number-of-rings-before-a-call-goes-to-the-voicemail/td-p/2576651
Aug 11, 2011 | Cell Phones
OUR PROSTAR 816 SYSTEM IS RINGING BACK ONCE WE PUT SOMEONE ON HOLD WAY TOO QUICKLY. IN ABOUT 30 SECONDS IT WILL RING BACK & i'D LIKE TO CHANGE THE RING BACK TIME TO AS LONG AS IT WILL ALLOW. CAN YOU...
To change the hold recall timer on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down enter #20 the screen should say MMC DISABLED
enter in 1 2 3 4 1 # (that enables programming)
The code for hold recall is #52
enter in your hold recall time in sec. and in a 3 digit format. i.e. 30 seconds = 030 a minute and a half is 090 and so on.
press # when finished
Aug 13, 2010 | Samsung Prostar 816 Phone
How to change the numbr or rings before...
1) With the phone in standby mode, press the menu/clock key three times.
You hear “Ring time” and the current ring time ([2 ], [ 4], [6 ], [T ] Toll
saver), and it is displayed on the main base. Then you hear the guidance for setting
the ring time.
2) Press the volume/select/ or up or down arrow key until the desired ring time appears.
3) Press the set key to select the new ring time. You hear a confirmation tone, then
the announcement “Ring time” followed by the new ring time. After a few
seconds, the system announces “To set record time, press menu again.”
Need the manual for your phone? You can download/print it here:
http://www.uniden.com/pdf/DXAI5588-2om.pdf
Bill B
Mar 04, 2010 | Uniden DXA15588-2 Twin Cordless Phone
How do i change the ringtone length on the samsung tocco lite gt-s5230 phone. it currently only rings for 3 seconds
if it goes to voicemail, means that you have to set the length of rings before voice mail. so you have to contact your service provider, and they can fix it on their end
Jan 02, 2010 | Lands Phones
We can't reprogram the phone afeter the power goes out.
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
1) enter in 1 2 3 4 1 # (that enables programming)
2) enter in #62 the screen should say day ring assn
3) press the line you wish to program
4) press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
5) press # when finished with the line
6) repeat steps 2 through 5 for the remainder of the lines you wish to change
hope that helps
Jan 27, 2009 | Samsung Prostar 816 Display Phone
I have problem with hold ring
In system programming, hold recall times are option 200. In the TD's IIRC they are adjustable from 0-240 with 0 being no recall. In a TA series, they have increments of 30-180 seconds or none.
Carl
Sep 17, 2008 | Panasonic KX-T7731 Corded Phone
Samsung Prostar 816
it sounds like the memory battery on the main board is no longer working which means that it'll happen again.
Aug 30, 2008 | Samsung Prostar 816 Phone
Number of rings
press *94, then press the number of rings you want 1-9. The tone will change and thats it.
Nov 29, 2007 | Siemens Gigaset S455 Cordless Phone
Lands Phones Logo
Top Lands Phones Experts
Marvin
Marvin
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
