A faulty thermostat or temperature sensor could be the cause of your Oster toaster oven's heating element not turning off when ready. You can try the following steps to fix the problem:
Check the settings for the temperature control: Check to see that the thermostat is not set too high. The heating element may not turn off even when the desired temperature is reached if it is set too high.
Get the toaster oven clean: Check to see that the toaster oven is clean and free of obstructions. The heating element may occasionally malfunction due to dirt and debris. You can get oven cleaner, https://amzn.to/3xlDd86 .
Check the temperature: The thermostat or temperature sensor may be defective if the problem persists. To fix the problem, you might need to buy a new thermostat or temperature sensor.
Contact Oster's support team: You can get assistance from Oster customer service if the problem persists after attempting the steps listed above. They might be able to offer you a solution or point you in the direction of a repair company.
your heating element has gone bad or there is some bad wiring in the oven itself
to check open up the toaster oven and look at the wires coming from the heating elements inside to the timer on the front panel if there is no bad wiring then the heating elements are bad and the toaster oven needs to be replaced
you are correct . it is the convection . the fan blows the air around and away from the elements ,when that is happening the elements can never get hot enough to glow , as the oven gets hotter and at some point the air is so hot even with it blowing the elements will start to get red ... this is good because todays elements are thin and cheep and melt easy so the fan keeps the heat away from them and the elements last longer ...... if this answer helped please rate it a 3 or 4 stars .this high rate will help keep me in the paid answer department ... thank you
you can touch the element but be carefull the glass is thin .... so scrape it and do what you can . THEN USE A COTTON BALL AND ALCOHOL and clean the element that will get rid of the oil you left behind ,you will be fine ......Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
this is all to common . what thought happend did happen . the control board went bad and the elements where stuck on . inside there is a thermal fuse ,it blew out and saved you from haveing a fire but now the oven is dead . if you replaced the fuse it would just do it again and the board cannot be bought so your out of luck . on your next oven stay away from electronic controls . i am shocked you got 3 years out if it ,most go bad mutch sooner
