Question about Avanti FF8SSR Top Freezer Refrigerator
Crisper glass cover for Avanti fridge
The bottom glass shelf broke, need replacement part
    Top Expert:
  • Avanti Master
  • 53,770 Answers
Have the local glass shop cut a new one for you
Posted on Dec 07, 2015
I need a glass shelf for the crisper drawers 22 5/8
The glass shelf is no longer available but having someone cut glass to size will work, Thanks Sea Breeze
Nov 19, 2012 | Refrigerators
Hi, i'm looking for a new 'veggie crisper box top shelf' about 13x17, and a 'bottom shelf' for the fridge door, Avanto Fridge Model# FF8SSR/FF8WR Cheers, Christian Lawson 6467846628
IF you go to Appliance Parts Depot and just put your brand along with your model number in the spaces provided then you should be able to order the parts you need your self. That away you can have them shipped to your house and not have to pay all the services fees that companies try to charge you for when they are going to do the same thing. Hope what info that i have gave to you is useful. If not you can email me at [email protected]
Jan 19, 2011 | Avanti FF8SSR Top Freezer Refrigerator
Need a new glass shelf for fridge and on oven the
the least costly way is to get a piece of glass from home improvment store and have it cut to fit
Jul 03, 2010 | Refrigerators
Water in wood's fridge
If you have the wire metal shelf model, there is a wrap around cooling plate (back and two sides) at the top of the inside. The frost that forms on this while it is running melts off after the compressor stops and the water runs down, into the drip channel, and out the drain hole at the center of the channel on the back wall. Clean out that hole so the water will flow out instead of down the walls to the bottom of your refrig.
If you have the glass shelf model, you have to remove the metal cover at the bottom back of the refrig and clean out the defrost drain hole located there.
May 21, 2010 | Refrigerators
I have an LFRD25850SW Fridge. The bottom shelf above the crisper drawers has cracked at the left front and is causing the drawer to stick. I need to replace the shelf frame (glass is OK). Can you give a...
The shelf frame is cracked . It can be purchased if the part is still available from LG . I wouldn't hold out hope though because LG is notorious for discontinuing parts after 3 years. Find a parts supplier who has contact with LG parts to see if it's still available . I was able to order one for my customer back in the spring.
Oct 22, 2017 | LG LRFD22850 Bottom Freezer Refrigerator...
CONDENSATION ON BOTTOM SALAD CRISPER SHELF OF A WHIRLPOOL INTERGRATED FRIDGE
cold,damp air,condensates on warm shiny surfaces(bathroom mirror),try putting kitchen towel under the crisper...(why they put crispers on bottom of fridge instead of on top of the cooling coils at the top of the fridge ???)
Mar 29, 2010 | Refrigerators
Broken shelf? help!
if it is the very bottom shelf then here is your part number 240354602.
if it one of the glass spill proof shelves here is your part number.240355211
Feb 09, 2010 | Frigidaire FRS3R5EMB Side by Side...
Cracked border to bottom shelf of frigidare refrigerator
240350614 is the part number for the shelf border that you need...price is around $26
Oct 03, 2009 | Frigidaire FRS3R5EMB Side by Side...
Glass shelf broken
Hi, there are replacements available. If you get me model#, I can get you part # and I can even order it and ship it to you.
Please let me know if you need more help.
Thaks
Vic
May 11, 2009 | Refrigerators
Bracket holding glass over fruit / veg compartment broke
http://www.partselect.com/Schematics/Maytag/54436.gif Maybe this diagram will help you. www.partselect.com I just replaced the Crisper Shelf Frame. I received it very quickly. I am now looking for some sort of support for the whole shelf, because it still seems to be sagging. I may have to invent something. If anyone out there has a solution, please post it.
Aug 26, 2008 | Amana ARB2217CSR Bottom Freezer...
Avanti FF8SSR Top Freezer Refrigerator Logo
114 people viewed this question
Top Avanti Refrigerators Experts
Marvin
Marvin
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
