Most treadmills have two screws at the back of the treadmill that adjusts tension on the belt. If the belt is staying on the left side of the treadmill pad then adjusting the left ***** out should make it go back towards the center.
I know this is way later...only 7 years!!. But these bikes or still around. I know because I just got one...Broke. 1. The Motor is bad... About $90 New.... 2.If it turns to Easy... The Belt could be off.
I put my belt on and #1 was hard to pedal. But did get harder with resistance increase which means the motor works! Too G??d!
LUBE THE DECK BELT SEE THE VIDEO ATTACHED 2) RUN THE SOFTWARE CALIBRATION FOR EASY DIAGNOSE, TROUBLESHOOTING AND FIX IT. GO under the HOOD motor, and follow the steps. God Bless you
Hi There is some problem in the belt tension. You have to tighten the belt of the treadmill. Check the following video which demonstrate how to adjust the treadmill belt. Ajin
You may have to buy a new belt because that one may have stretches. After you buy a new belt. Look at he alternator, it has two screws, one hold it in place and the other allow it ti move. Lose both a little. With a pry bar push the alternator so the belt can fit. Look for the belt routing diagram in the engine compartment. Follow it and put the belt on. You were suppose to have a belt tension tool to determine the tension. Then use your pry bar to move the alternator to position and tension then tightened alternator screws.
