Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily
Hint: Almost all the urc remotes have same codes
http://electro-medical.blogspot.com/
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC3220
just right click and save as on the download links.
if this does not work you can try the search method,
you do
this by either holding down the device button eg: TV or if you have one
the "magic" button for three seconds, a light should then flash twice
to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
SOURCE: Remote code
http://www.ofausa.com/remote.php?type=URC4041
you do
Many thanks
Mark
(For low price replacement remotes visit www.sparky-uk.com)
SOURCE: ONE FOR ALL URC-4640B01 REMOTE
on the remote press tv once press and hold set until the LED blinks twice then release set enter 9-9-1 The led will blink twice aim the remote control at the tv and slowly alternate between pressing power and tv stop when the tv turns off to lock the code press and hold set until the led blinks twice
SOURCE: i have the urc-4640B01 remote and i dont have the
These are the codes, I used for my Emerson TV's. 0002, 0294, 0479. Hope this helps you!
SOURCE: I need setup codes for an old One For All remote
Please click on the following link:
http://www.oneforall-na.com/arc_manuals/46_05_40_50_codes.pdf
These are the codes for the 4640 4605 and 4650 OFA remotes. You can save and/or print this file after you have downloaded it. This is an old remote and the instruction manual is no longer available for download from the manufacturer, but if you do need instructions, please post back and I will try to obtain it for you.
Please note, older remotes often don't work with new televisions and other devices.
Regards
BElectric
Testimonial: "Thanks :D "
0154 0236 0463 0180 0282
0178 0019 0179 0177 0185
0623
OK.
