Hello there,
First I will put the problem straight to you, which is that your television is not connected to the Satellite source you have, be it local satellite or decoder.
1. You need to check first the connection to any antenna source or decoder.
2. Go check the direction of the antenna or decoder, trace the wires for any breakage (if any see to it that its properly corrected and taped),
3. and see to it that all plug ins are properly connected i.e. RF connector,
4. check to see that the decoder is properly connected to a power supply and turned on.
5. Turn on your tv, go to your auto tune and search again or you can do a manual search.
After that, it should work perfectly once again.
All the best with that.
Take care
TV programs can only be viewed when an external antenna or Satellite dish is connected to the TV. So, if its not showing, it means there's a problem with the connection to your antenna or Satellite Dish. So, the process I put to you is a way of reconnecting your television to your antenna. And that's what will bring about Channels showing and clear.
My LG plasma TV 50pc3d when power-on only see vertical bars. what 's going on. please help. Thank you
SOURCE: tuning option on menu is greyed out. cannot retune channels
If the channel icon is greyed out and you cannot tune the channels press the TV/DTV button on the remote control unit the icon is not greyed out and tuning is possible.
SOURCE: Auto Tuning Channels on LC20B2MA Aquos TV
Automatically tunes in and preset
receivable TV stations.
Make sure the antenna cable is
properly connected.
1 Press MENU (PRESET-1) on the
upper part of the LCD TV set for
more than two seconds. The
AUTO mode screen appears.
2 Press VOL (–)/(+) (PRESET-2)
on the upper part of the LCD TV
set.
All the TV stations in your area
that can be received by the LCD
TV set are automatically preset.
3 The screen shows whatever is on
channel 1 when full auto channel
preset is finished.
SOURCE: how to do a manual channel tune on a Samsung 933HD TV
in every remote there is a button that leads u to the digital setup. you have 2 options in it. manual or automatic. go for automatic. rest is done automatically. good luck!
SOURCE: my LG tv wont tune all digital channels? im
Tv may need a firmware update or the Ch. is blocked in the Ch.menu.
Give LG a call @ 1 800 243-0000 they can give you more details.
