Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Door won't open
SOURCE: Garage opener/ brand garage master 1/3 HP
trolley is not attatced to the chain, grab that red rope that is hanging down and give it a ****. run the door up until it re-locks onto they trolley
Posted on Mar 30, 2008
SOURCE: keypad garage door opener will not operate
what keypad are you using with new opener? Frequency has changed. can't use old one. you probably never needed to change things; just needed to follow proper coding procedures.
Posted on Jan 28, 2009
SOURCE: Garage Opener Model 3255 Chamberlain Lift Master
The most common cause of this problem is a bad wall control the wiring going to it. You can eliminate both temporarily by removing the wire at terminal 1 on the back of the motor unit. The wiring sometimes is shorted by the staples the installer uses. The wall control gets used a lot.
Posted on Jun 23, 2009
SOURCE: Access Master Garage Door Opener opens by itself
The most common cause of this is a bad wall control or the wiring going to it. The wall control goes bad from use and the wiring sometimes has intermittent short caused by the staples the installer used.
Posted on Jul 31, 2009
SOURCE: Sears Craftman Garage door opener model # 41A3493-1
That isn't the model number you give it is the part number for the logic board. The model number is on the opposite end of the motor unit and starts with 139. If you are asking if the opener should reverse when it hits an obstacle the answer is yes. If it doesn't it is not adjusted correctly or is faulty.
Posted on Dec 01, 2009
Dec 06, 2014 | Building Materials
Aug 08, 2014 | liftmaster Lift Master 377LM 376LM 315 MHz...
Jul 17, 2012 | Sears Craftsman LiftMaster Chamberlain...
Jun 13, 2012 | Sears Craftsman LiftMaster Chamberlain...
Oct 02, 2011 | Sears Craftsman LiftMaster Chamberlain...
May 10, 2011 | Sears Craftsman LiftMaster Chamberlain...
Oct 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Jul 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Jul 03, 2009 | 2003 Lexus ES 300
Feb 06, 2008 | Sears Craftsman LiftMaster Chamberlain...
889 people viewed this question
