How to unlock childproof lock - Washing Machines
Posted by Chong on
prem mathew
  • Washing Mach... Master
  • 662 Answers
Press and hold down gently the LOC button for 5 seconds or more, the light will go off - your machine is unlocked !! You do it again & the machine is locked. This is a tamper proof device against children. Gud luck. Comment?
Posted on Dec 06, 2015
NN-ST671S microwave is locked and wont function Is their a childproof lock on it and how do you unlock it
There should not be a childproof lock on your microwave.
However, it is remotely possible that there is electrical failure preventing the door opening.
Most, not all, microwaves can be taken apart with screws with the door closed.
See if you can do yours.
You should find the latch holding the door is broken or stuck or whatever.
God bless your efforts.
Nov 13, 2017 | Microwave Ovens
How to turn off childproof lock on remote
hold down the mode button and the up arrow button at the same time
Dec 24, 2013 | Heat and Glo Home
Fisher & Paykel dryer DE60F60EW1 has suddenly stopped working when I tried to change the program. How do I reset the machine
Here are a couple of possible reasons it stopped and solutions from the manual.
Adding/removing laundry in standby mode
If you want to add or remove laundry into/from your machine after the drying programme has
started, put the machine into Pause mode by pressing the START/PAUSE/CANCEL button. The
drying process will stop. Open the door at Pause position and close it again after adding or
removing laundry. Press START/PAUSE/CANCEL button to start the programme.
Any laundry added after the drying process was started may cause the already dried clothes in
the machine to intermingle with wet clothes and the result will be wet laundry after the drying
process is over.
It is not recommended to add laundry after the programme is started as it will increase the
programme time and energy consumption.
Childproof lock
There is a childproof lock to prevent any programme interruption due to the pressing of keys
while the programme is on. The loading door and all keys except the ON/OFF key on the panel are
deactivated when the childproof lock is active.
In order to activate the childproof lock, press on the StARt/PAUSe/CANCel and BUzzeR CANCel
buttons simultaneously for 3 seconds.
Fig.6 Using the
childproof lock
To start a new programme after the programme is over or to interrupt the
programme, the childproof lock should be deactivated.
To deactivate the childproof lock, press the same buttons for 3 seconds.
Two beeps will sound when the childproof lock is activated. A single beep
will sound when the lock is deactivated.
I was able to view the manual by a Google search and the third item on the Google search list was the manual, but it would only come up by selecting "quick view", otherwise it would crash the Acrobat reader plugin.
Jun 03, 2012 | Toys
1998 Isuzu Trooper LS - How do you release the "childproof locks" on the back doors?
IF YOU OPEN THE BACK DOOR THERE SHOULD BE A SMALL LATCH THERE ON THE DOOR ITSELF SHOULD SAY LOCK AND UNLOCK SWITCH TO UNLOCK
Feb 05, 2011 | Isuzu Trooper Cars & Trucks
Childproof lock on
May I get the make and model # to help you more.
Apr 18, 2010 | KitchenAid 24 in. KUDP02CR Built-in...
How do you unlock a childproof lock on a washing machine?
hold the lock button down for three seconds and it will release
Mar 29, 2010 | Washing Machines
Reset childproof lock siemens washerWM16S760DN
Set it to the last programme you had it on then press and hold the timer button for about 5 seconds.
Feb 06, 2010 | Siemens Washing Machines
PANASONIC MICROWAVE NN-K657
To UNLOCK it, press Stop/Clear 3 times.
To LOCK it, press Start 3 times.
You can download your owner's manual here:
http://techdocs.panasonic.co.uk/GetDoc.aspx?did=125787&fmt=pdf&lang=en&src=3
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 24, 2008 | Microwave Ovens
Childproof Lock
Hello mine is a WM14S79BUK but i think it works on most recent models with lcd display.
I have to hold the down button on the option buttons for 5 seconds to activate child lock or unlock
it's worth A TRY
Hope this helps
Jun 07, 2007 | Siemens WIQ1433 Front Load Washer
Washing Machines Logo
77 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
