Question about Husqvarna Fast Tractor YTH24V48 48" 24HP Lawn Tractor 2014 Model - 960 43 01-82
How do you lock differential? - Husqvarna Fast Tractor YTH24V48 48" 24HP Lawn Tractor 2014 Model - 960 43 01-82
Posted by Robert Stith on
Claude Kayser
    Top Expert:
  • Husqvarna Master
  • 9,098 Answers
The locking is automatic:
Husqvarna riding lawn mowers, lawn tractors, garden tractors
www.husqvarna.com/us/products/riding-lawn-mowers/
Husqvarna GroupThe available, electronic or automatic locking rear differential increases ... forHusqvarna lawn and garden tractors, you are ready for every season. ... Why use your ride-on mower only for lawn mowing, when it has the capability to do so much more. ...Kawasaki V-Twin engine; Fast hydrostatic transmission; Cruise control ...
Husqvarna Riding Lawn Mowers YT48XLS CARB
www.husqvarna.com/us/products/.../960430205/
Husqvarna GroupBy using this site, you agree to our use of cookies. Learn more. Got it. Close .... Wedeveloped our LS series yard tractors with the discriminating landowner in mind. Engineered for added ... Automatic locking rear differential increases traction while cutting wet grass or on slopes. ..... WORKING FAST WHILE STAYING SAFE.
Husqvarna Riding Lawn Mowers GT54LS
Posted on Dec 06, 2015
2009 trailblazer rear drivers side axle won't come out. c clip is out
Special Tools
  • Slide Hammer
  • Axle Remover
Removal Procedure
  1. Raise the vehicle. Refer to Lifting and Jacking the Vehicle.
  2. Remove the tire and wheel assembly. Refer to Tire and Wheel Removal and Installation.
  3. Remove the brake caliper. Refer to Rear Brake Caliper Replacement.
  4. Remove the rear wheel speed sensor. Refer to Rear Wheel Speed Sensor Replacement.
  5. Remove the rear axle housing cover and the gasket. Refer to Rear Axle Housing Cover and Gasket Replacement.
  6. Remove the pinion shaft locking bolt.
  7. On axles without a locking differential, remove the pinion shaft.
  8. On axles with a locking differential, remove the shaft part way. Rotate the case until the pinion shaft touches the housing.
  9. On axles with a locking differential, use a screwdriver, or a similar tool, in order to enter the differential case and rotate the C-lock?(1) until the C-lock aligns with the thrust block?(2).
  10. Push the flange of the axle shaft?(1) toward the differential.
  11. Remove the C-lock from the button end of the axle shaft.
  12. Note: When removing the axle shaft, do not rotate the shaft. Rotating the shaft will misalign the gears. Misaligning the gears will make the installing of the axle shaft difficult.
  13. Remove the axle shaft from the housing.
  14. Hope this helps?
Apr 09, 2018 | Cars & Trucks
How to replace rear axel wheel bearing and seal on 2006 jeep liberty renegade 4wd
its not just the seal.... i bet,
99% of seals that fail are , the bearing is allowing , out of spec.
moving in the axle
so when doing all that hard work ? we check this first.
do you know all cars have this book, called the FSM.
and all show you how this is done? every one.
factory service, manual,
but hark, we have them on line now.
alldata.com (15 BUCKS)
I BET PART 2 AND 3 ARE BAD HERE
http://www.factorychryslerparts.com/showAssembly.aspx?ukey_assembly=533119&ukey_product=4240348
THE REAL CD IS ABOUT $130 (instant payback first job done by you) see?
https://www.techauthority.com/en-US/Pages/Home.aspx
eg.
Removal & Installation
  1. Before servicing the vehicle, refer to the Precautions section.
  2. With vehicle in neutral, position vehicle on hoist.
  3. Remove differential housing cover and drain lubricant.
  4. Rotate differential case so pinion mate shaft lock screw is accessible. Remove lock screw and pinion mate shaft from differential case.
  5. Push axle shaft inward and remove axle shaft C-lock from the axle shaft.
  6. Remove axle shaft from side gear and axle tube.
  7. Remove axle shaft seal from axle tube with a seal pick.
To install:
  1. Remove any old sealer/burrs from axle tube.
  2. Coat new seal lip with axle lubricant and install seal with a seal driver.
  3. Lubricate bearing bore and seal lip with gear lubricant.
  4. Install axle shaft through seal, bearing and engage into side gear splines.
  5. Install C-lock in axle shaft end, then push axle shaft outward to seat C-lock in side gear.
  6. Install pinion mate shaft into differential case and through thrust washers and differential pinions.
  7. Align hole in shaft with hole in the differential case and install lock screw with Loctite on the threads. Tighten lock screw to 8 ft. lbs. (11 Nm).
  8. Install the differential cover.
  9. Install rear brake components.
Sep 06, 2014 | 2006 Jeep Liberty Renegade
02 Silverado G80 differential is not locking according to the g code in my glove box I have a G80 differential but I have had my truck spining tires on road and off road my differential dose not lock in...
remove differential cover and rotate carrier look in the area around the axle gear small teeth can be seen with little gears that come to a flywheel weight governor (g80) that spins and tightens the axle gears against the carrier creating posi. works only under power
Jun 10, 2014 | Cars & Trucks
I have changed 4WD Actuator on my 2007 Toyota 4Runner. Now the Central Differential Lock isn't coming off when pushing(but don't know if before it was working). I push to Unlock the Differential but i
Put back on H2 or all normal, remove both battery cables from the battery, without touching the battery, hold the positive and the negative cables together for 30 seconds, then return the cables to the proper posts on the battery. This will drain all memory at the ECU, the next 10 or so miles , under normal driving will re- teach the computer. I hope this improves the issue!
Dec 03, 2013 | 2007 Toyota 4Runner
Differential carrier
if you have rear wheel drive you could have a broke C LOCK on the inside of the differential whicn means you have to remove rear differential cover to replace C LOCK on driver side.
Aug 25, 2012 | 1985 GMC S-15
How to put in four wheel drive
FOUR-WHEEL DRIVE SYSTEM
(a) Four-wheel drive control
Use the four-wheel drive control lever and center
differential lock button to select the following transfer and
center differential modes.
The "H" and "L" position of the four-wheel drive control lever
provides either lock or unlock mode of the center differential
depending on the center differential lock button position.
Use the center differential lock system if your wheels get stuck
in a ditch, or when you are driving on a slippery or bumpy
surface. When the center differential is locked, the vehicle
stability control system is automatically turned off and the
center differential lock and "VSC OFF" indicator lights come on
because the function that controls engine performance
As soon as the center differential lock switch is turned
on, the "VSC OFF" indicator light comes on. After the
wheels are out of the ditch or off the slippery or bumpy
surface, turn the center differential lock switch off.
Make sure the center differential lock indicator light and
vehicle stability control system off indicator light turn
off.
"H" (high speed position, center differential unlocked):
Lever at "H", center differential lock button left out
Use this for normal driving on all types of roads, from dry
hard-surfaced roads to wet, icy or snow-covered roads. This
position gives greater economy, quietest ride, least wear and
better vehicle control.
"H" (high speed position, center differential locked): Lever
at "H", center differential lock button pushed in
Use this for greater traction when you experience a loss of
power, such as wheel slipping, in the center differential unlock
mode.
"N" (neutral position): Lever at "N"
No power is delivered to the wheels. The vehicle must be
stopped.
"L" (low speed position, center differential unlocked):
Lever at "L", center differential lock button left out
Use this for maximum power and traction. Use this for climbing
or descending steep hills, off-road driving, and hard pulling in
sand or mud.
In this mode, the braking feeling that occurs when the wheels
are negotiating a sharp corner is further reduced than in the "L"
(low position, center differential locked) mode.
"L" (low speed position, center differential locked): Lever
at "L", center differential lock button pushed in
Use this for maximum power and traction. Use this for hard
pulling in situations the vehicle cannot negotiate even in the "L"
(low speed position, center differential unlocked) mode. Also,
using this mode when driving down steep off-road inclines will
help contribute to increased vehicle stability.
https://secure.drivers.lexus.com/lexusdrivers/info/my-lexus/resources/submit-owners-manual-search.do
Please copy and paste the link above and it will take you to the lexus site. There you will find the owners manual and you can download whatever sections you need for free.
Hope this helps.
Feb 11, 2011 | 2004 Lexus GX 470
Rear axle removal ? i want to take to replace two broken lug nut bolts
to remove the rear axle you will need to put the rear of the jimmy on jack stands off the ground and remove the wheels
then remove the rear drums or if you have disc brakes the caliper and rotor
next you will need to remove the rear differential cover
once you have removed the rear differential cover you will need to rotate the differential by just turning the rear axle to gain access to the lockbolt
using an 8 mm socket you should be able to fairly easily remove the lock bolt
once you have removed the lock bolt you will need to push the axle in from the side that the wheel gets mouted to and then in the rear differential remove the locking 'c' clip
once the locking 'c' clip is removed you should be able to pull the axle right out
installation is the reverse of the removal
keep in mind that after romoving the lock bolt you must make sure not to rotat the axle if you do you will mess up the allignment with the differential and axle and you will spend loads of time trying to re-allign it again
hope this helps
Aug 13, 2010 | 1996 GMC Jimmy
When i engage in 4 wheel drive,the jeep jerks when i turn and i hear a cracking noise,can it be my bad rotors an brakes?
I think what you are hearing is the CV joints complaining about the Differential being locked. Check to see if the Diff lock lamp is on or if the button has been pressed. When you trun a corner, the wheel on the outside of the turn has to travel further then the inner wheel, because of this, the outer wheel rotates faster and this is made possible by the differential. If the differential is locked then usually the inner wheel has to skip along or the CV joints start to jump over the balls (which is NOT good) Locking the differential means that the gears that allow one wheel to rotate faster then the other one are locked together and the wheels MUST turn together. This prevents loss of drive through the differential as it forces both wheels to rotate together, handy if you get bogged or are driving over sand or soft ground. But not recommended if you are driving on sealed roads..
Dec 27, 2009 | 2000 Jeep Grand Cherokee
My 2004 Mercury Mountaineer will go into gear but will not move. What could be the problem
Your rear emergency brakes could be hung up. Especially if a parking valet or someone else parked it recently.
You need to jack up both rear wheels and then put your car into neutral with the motor OFF. If the rear wheels can not be manually turned it is either the emergency brakes, the differential or the transmission.
The emergency brakes require removing the back tires and rotors. If it is still locked, then it is either the differential or the trans. The driveshaft connects the trans to the differential so remove the driveshaft. If the differential turns without the driveshaft, then the trans is locked up. If the differential does not turn the problem is inside the differential.
Nov 18, 2009 | 2004 Mercury Mountaineer
Differetial locks for 94 land cruiser
91-97 Land Cruisers had a factory option for front and rear locking differentials. This is a seperate switch and is usually located to the left of US model Land Cruisers. The center dash button locks your transfer case differential changing your Land Cruiser from all wheel drive to four wheel drive depending if you have ABS or not this button either says ECT or Center Dif Lock. If you do not have the Front/Rear locking differential option then your Land Cruiser has open Front and Rear. Hope this answers your question.
Jan 19, 2009 | 1994 Toyota Land Cruiser
Husqvarna Fast Tractor YTH24V48 48" 24HP Lawn Tractor 2014 Model - 960 43 01-82 Logo
316 people viewed this question
Top Husqvarna Garden Experts
bryan st
Marvin
Marvin
dannydoesita
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
