SOURCE: rolling white lines
sometimes this can be caused by two connected devices being on the same av channel,try connecting one at a time,also check your tv is set for your region etc,pal or ntsc.and you could look in your tv settings menu and check your output ie rgb scart,forgot the other options,,hope this helps
SOURCE: Vertical white lines across screen
whatever brand your tv is go there .com maunals it should show u what u need to know
SOURCE: Phillips 55 inch rear projection tv red convergence screwed up
Install the DPTV305_DPTV345 Chassis convergence repair kit. You can get the kit at the following link and it contains the parts plus instructions on CD.
http://www.tvrepairworld.com/
SOURCE: my hitachi 55 in. tv is having problems with the
The convergence IC's need to be replace on the convergence board, or just buy a new convergence module, and that will fix the problem.
