Question about Liebherr HCS2062
French doors don't close without a push.
Gaskets were replaced
Posted by Kim Corfman on
mike cooper
  • 884 Answers
Take the gaskets out again. warm them in very hot water for 5 mins before refitting them on the opposite door. Then adjust the hinges to check. Also make sure the shelves are pushed right the way in, not keeping the door open.
Posted on Dec 18, 2015
Need Seal replaced
Carolyn,
If this is a commercial freezer we offer a custom made gasket option. It's a simple process at coolergaskets.com
Step 1: visit our custom made gaskets page HERE and identify the gasket profile material that best matches your existing gaskets.
Note: If you have a hard time with this we offer a $1 gasket sample ring.
Step 2: Input the outside edge dimensions you need your gasket to be (length and width) and how many sides it has (3 sided gaskets are most common for walk-in coolers/freezers, You will want precise measurements. Here's our " How to measure your gasket" video.
Step 3: Select the quantity you want and add that gasket to your cart where you will be able to proceed to check out there. Then relax because your gasket is in good hands!
Oct 14, 2013 | Frigidaire 12 cu. ft. / 340 liter Upright...
My Kenmore frost free freezer is not getting cold enough, door seals correct and it is leveled the compressor is cycling fine and there is no ice build up, help
Hey Betty,
One suggestion is to check and see if your freezer's gaskets are in need of replacement. Cracked, torn, warped gaskets can be the cause of not being able to keep the cold in. We have universal gasket kits for residential coolers and freezers just click here to view our options. Or give me a call and I'd be happy to help!
- Nicole
1-877-442-7538
Sep 23, 2013 | Kenmore Freezers
Do true kegerator parts have to be replaced with true parts
Depends on what part you are looking for. I use condenser motors, evaporator motors, thermostats, and even compressors and capillary tubes that I sometimes get at local suppliers. If you're looking for gaskets, hinges, panels, tap heads or something like that it may be easier to get from True.
Dec 31, 2012 | True Direct Draw Systems: Kegerator TDD-3
The seal on the door of my Ariston fridge/freezer has gone. Part Number BC 312 AL. Can you tell me how much a replacement would cost and how long to deliver to France. Thankyou
You will have to find an appliance parts retailer that sells those refrigerator gaskets. Fixya does not sell parts, i dont think
Sep 27, 2010 | Freezers
THE TOP HALF OF FREEZER SEEMS TO BE FROSTING OVER ALL THE TIME BUT THE BOTTOM HALF STAYS NORMAL
Check your door gaskets. Tale a dollor bill and put all around your door gaskets you should have to pull it out. If it is to easy you have found your probldem
Sep 12, 2010 | Freezers
How do I replace the door gaskets on a Delfield Model 6051 refrigerator? I can't see how to get the plastic inner panel off to release the gaskets and there is no help in the operating manual.
from what their web site shows, all of their gaskets are some sort of push in (Dart type) or clip in on a strip. Removing the inner panel is not necessary.
http://www.delfield.com/docs/uploaded/del/Parts/dpc08.pdf
go to page 36 and it shows the construction of the their gaskets.
Aug 02, 2010 | Delfield Freezer 6151XLSR Stainless steel
I have a whirlpool chest freezer wcn9-1. & its condensating really bad causing puddles. Can I stop it? There is a button at the front low down that sticks out & glows red when out. If its pushed in...
check your gaskets. If the gaskets don't make a tight seal it can condensate close to the gaskets. the red light indicator light more than likely refers to a moisture control and it should be on.
Feb 01, 2010 | Whirlpool Freezers
Liebherr HCS2062 Logo
192 people viewed this question
Top Liebherr Freezers Experts
Tom Chichester
ray gallant
Are you a Liebherr Freezer Expert? Answer questions, earn points and help others
