Question about GE Ovens
How do I clear an error code FO on my GE oven
Oven displays and beeps with error code FO, turned off power and once power is turned on again, after ~12 standing/without use, error code reappeared. How can I clear this error code?
    Habit-Forming:
    New Friend:
  • 23 Answers
It usually means the touch pad or the oven control is defective.
Posted on Dec 17, 2015
5 Suggested Answers
Anonymous
  • 3 Answers
SOURCE: JTP56 Double Oven Beeping and Display FO Code
http://www.fixya.com/howto/h155060-dreaded_f7_error
Posted on Jul 26, 2008
Anonymous
SOURCE: F1 error code
disconnect the power undo the three screws that hold the panel in place and behind the panel if you look you will see a 1 1/2'' wide electrical ribbon that sends info to and from touch pad .... ok heres the fix what causes the F1 is a short were the ribbon goes through the little metal slot (rubbing ) put some caulk on a business card and carefully put between metal and ribbon (you will only get to push the card in about 1/8'') but this and the caulk will be suff to keep the ribbon shorting, replace panel and screws power back on , it should now be ok
Posted on Oct 20, 2008
jumptrout51
steve
  • 3361 Answers
SOURCE: GE Profile oven beeps and displays FO
Your electronic oven control(clock) is bad and must be replaced.
Posted on Sep 02, 2009
Anonymous
SOURCE: Ariston oven error code F8E0
solved by rotate the temperature knob!!!
maybe would be a problem of the potentiometer or knobe of temperature
Posted on Nov 22, 2009
Anonymous
SOURCE: How do I fix my GE True temp oven which shows F7 on the display?
https://www.youtube.com/watch?v=Rg7Dp4LBxtA
it seems its the connections ribbons on the control panel is wrong
will give you a clue look down the replys to the video to get more info
some very carefull cleaning is needed inside the front panel rework some connections
i use deoxit 5 and a rag
spray the deoxit to a rag then wipe the connection ribbons
then dowse the plugs with the deoxite
wait a while and re plug then carefully
should cure it
i would add a blob of grease to the sockets once its all running
to avoid further corrossion
hope this helps
Posted on Dec 11, 2014
My oven has code Fo displayed. It began with a beeping. We turned off the breaker and turned it on again. The beeping continued. After several attempt the beeping has stopped but the code remains...
Hello, I had the same FO error. It turned out that the ribbon cable from the front panel was not making good contact where it mated with the circuit board. Remove ribbon cable and clean contacts on ribbon cable. Replace cable and problem should resolve.
Thanks
Jul 14, 2010 | GE JGRP17 Gas Single Oven
FO error message. Oven light stuck on. No buttons work.
The F0 is a Function Key Stuck error - Replace touch pad or touch pad and control board if it is one assembly. Refer to F1 Test for more information.
How To Perform A F1 Touch Pad / ERC Test
This test is easy to perform and will help you determine whether the Electronic Range Control (ERC, control board) or touch pad is defective when the F1 code is displayed.
Note: With some models, the ERC and the touch pad are one single unit and therefore this test is not necessary. The entire assembly must be replaced.
Warning: If you have any doubts in your ability or safety of the repair, please contact a qualified appliance repair technician.
1. Disconnect the power to the range by either unplugging the power cord, or turning the power off at the circuit breaker. Always make sure the power as been disconnected properly before beginning this test.
2. Access the control panel.
3. Disconnect the touch pad ribbon from the ERC.
4. Reassemble the control panel. Make sure to check for any additional defects such as frayed or lose wires that could be causing the problem.
5. Turn the power back on.
6. Wait up to an hour for the F1 code to reappear. This could be accompanied by an alert such as a beeping sound.
7. If the F1 code reappears, replace the ERC. If it does not, replace the touch pad.
Nov 06, 2009 | GE Monogram ZET3058SHSS Stainless Steel...
Jun 28, 2009 | Ariston Technologies Ovens
GE JT912-30 single wall oven "help" with F7 - F0 error
I have a double oven GE Profile. The error message FO appeared. I shut off the circuit breaker for 30 minutes or more and the oven works but without warning FO reappears. FO message means there is short in the clear Off touch button. The only solution replace the complete panel. My cost delivered $328. Ouch!
Jan 19, 2009 | GE Profile JKP56 Electric Double Oven
May 18, 2008 | GE Profile JTP56 Electric Double Oven
Error Code F8
F8 Analog/Digital supervisory Replace clock assembly (also called the ERC)
ohhh thats not good, escpeccially with company coming, replacing the clock appox 175 for part, def wont happen by tommorow nad no you cant separate the 2 ovens both ae wired together
Mar 15, 2008 | Jenn-Air JJW8230D Electric Double Oven
Fo function error code
The F0 usually means that there is a problem with the keypad.
My solution for the F7 problem may help. You will find my solution at the following link.
http://www.fixya.com/howto/h155050-dreaded_f7_error
I have now shared my fix with over 1600 folks and most report success. I hope that it works for you too. Please let me know at:
[email protected]
Charlie Popeck, P.E.
Consulting Engineer
Mar 07, 2008 | GE Profile JKP56 Electric Double Oven
Error code F1 and beeping
Means replace the $300 control board. And if your like me.....do it twice within 12 months.
Jan 30, 2008 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
691 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Ekse
Marvin
Marvin
Are you a GE Oven Expert? Answer questions, earn points and help others
