Question about Apple iPod Audio Players & Recorders
My ipod screen has stopped responding any suggestions?
This is a 30gb model and is quite old, it was working fine a few weeks ago when switched off.
Posted by Edward Curran on
Frederik Botha
    New Friend:
Hi, I don't know if you solved the problem with your iPod but you can try this as I had a similar problem and it worked for me:
Most problems with these older iPod's can be solved by resetting it (and I didn't lost anything stored on the device).
To Reset iPod:
1. Connect iPod to a power outlet using the iPod Power adapter.
2 Toggle the Hold switch on and off (set it to Hold, then turn it off again).
3. Press and hold the Select and Menu buttons for at least 6 seconds, until the Apple logo appears.
That's it. hope it solves your problem.
Posted on Dec 05, 2015
My I pod stopped working
How old is the battery ipod batteries can only be recharged a certain ammount of times before they need replacing
If an iPod appears not to turn on, check the hold switch on the device.
If this switch is activated while the device is off, it will not power on again until the hold switch is turned off.
If that is determined not to be the problem, the battery's charge should be checked. When the battery is no longer holding a charge, the device will not power on, but will show a battery icon on the screen for a few seconds.
If you see this icon while trying to boot up the iPod, just connect it to the USB cable and allow the battery to charge, which can sometimes take up to 30 minutes before the iPod becomes operable again.
If no battery icon appears when trying to turn on the device, try resetting the iPod.
Once reset, the device should turn on, but if it does not, the battery may need to be drained first (by leaving the iPod disconnected from power for up to 24 hours), and the reset procedure tried again.
hope this helps
Aug 19, 2012 | Apple MA146LL/A 5th Gen Video iPod 30GB -...
30GB iPod video, connected it to a USB charger, now it's screwed.
Few months ago i have same problem with my apple ipod classic 30GB.
My USB cable is short so computer show that, USB device canot be recognized. I haver replaced my cable. Problem will be in USB slot of ipod.
Replace cable. Problem will be solve.
Sep 23, 2009 | Apple iPod MA446LL/A MP3 Player
The screen won't light up on my ipod, but
Unfortunately there is no solution since the water has messed up the LCD. Have you tried going to settings and check if the back light option is on?
Mar 31, 2009 | Apple iPod nano
Ipod nano is dead
leave it on until the battery runs down.turn off and plug in to charge,Allow it to fully recharge.Turn on and it should have reset itsself.
Feb 11, 2009 | Apple iPod nano
Ipod 4g non responsive
Its unlikley that it was caused by sweat particularly if it was in a case. You may want to check that it isn't a firmware issue by restting it (hold down menu and center buttons - WARNING: wipes memory). If that isn't helping send it in.
Nov 28, 2008 | Apple iPod nano
Windshield wipers stopped working
quite possibly and most likely your problem is in the switch itself and needs replaced hope that helps you
Aug 20, 2008 | 1993 Jeep Wrangler
My ipod middle button doesnt work what can i do help
The problem is that the battery gets old and swells up and presses on the back of the button. I had to pop it open after watching a few youtube instructions, but the only way to get the button to stay unstuck was to leave the case slightly open at the top. When I close the case the swollen battery stops it working again. Tried removing the foam backing from the hard drive, but this did not help. It still works great now in my docking station but I would not want to take it portable with the case not properly closed.
Jul 09, 2008 | Apple iPod nano
Ipod 30GB
Did you try different charger?
try the following solutions:
1: Try charing through the USB cable which comes along the IPOD.
2: If you have direct electricity charger, try charging it. its easily available in the market.
If none of the above works, then possible the IPOD Battery has gone bad, try replacing it from a trusted source.
All the best!!
Regards,
Shalini Sharma
***MIND POWER COURSE***
http://blog.goldeninspiration.com
Apr 24, 2008 | Apple iPod MA446LL/A MP3 Player
Apple iPod Model A1136, 30 GB.
First make sure your hold switch isn't on. It's on the top or bottom and slides back and forth. It needs to be switched to the left. Once it is to the left, here's how you reset:
You can reset your ipod by holding down the menu and select (round button in the center) buttons down for at least 10 seconds. You'll see an apple logo flash, that's when you stop pressing the buttons. It will shut off, then back on.
Feb 14, 2008 | Apple iPod MA446LL/A MP3 Player
60 people viewed this question
Top Apple Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
Geoff
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
