Question about Fellowes Office Equipment & Supplies
Can anyone tell me where I can find a replacement large toothed wheel 10 cm diameter which slides onto the hexagonal shaft of my now obsolete Fellowes SB 97Cs shredder
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 36 Answers
How do I fix belt on my hotpoint TVM570p dryer
To do the belt. + as long as your patience lasts...
1. UNPLUG the washer.
2. check you've unplugged.
3. Open the top of the machine - see the sides of the lid about 10 cm from front, remove plastic cap on each torx head, undo torx. (torx set required)
4. Remove concrete block from top - large spanner is required - remember the sequence so you can replace later.
5. Lean over the drum and see the large drive wheel. To pop the belt off, turn the wheel forcing the belt to the edge of the wheel. It will eventually come off.
6. to replace belt - see motor shaft at bottom of unit. Dangle belt round shaft of motor and gently pull so it does not come off.(This is not easy!)
7. At the same time Ease one side of the new belt back on to drive wheel on the back of the drum.
8. Turn Drive wheel until belt is on.(This is not easy and requires alot of hand strength)
9. Replace concrete block with bolt and spanner in reverse sequence you removed it.
10. replace lid, torx and cover for torx.
Oct 14, 2012 | Dryers
How to put steering wheel back on
Are you talking about the spring and C-clip that go on the steering shaft UNDER the steering wheel? There is a special tool required to do that. However, I MADE a tool to accomplish this task by using a short piece of electrical conduit that was jus large enough in diameter to slide down over the steering shaft. (I think it is 5/8" conduit - can't get to my tool box right now to check) Anyway, measure the diistance from the end of the shaft to the groove where the C-clip snaps in. Cut a piece of conduit to this length. Then put your spring on and slide the C-clip on as far as you can by hand. Then put the piece of conduit over the shaft so it is contacting the the C-clip. Then use a flat-washer on top of the conduit and insert your steering wheel fastening bolt into the washer/conduit apparatus and screw it into the shaft. The bolt and washer will push the conduit, which will force the C-clip to slide down the shaft and compress the spring. When you screw it far enough, you will hear the C-clip "Click" into the groove. Voila! your spring and C-clip is installed. Unscrew the bolt and remove the conduit and washer, then assemble the rest of your steering column/steering wheel components.
Dec 24, 2011 | 1995 Ford F150 Styleside Regular Cab
I need an axle for the wheel of a common bicycle whit an diameter of 42 cm.(the wheel) I'll pay c.o.d.I'm waiting for a n answer. Attention, the back wheel!
The diameter of the rim tells us nothing about the axle. The hub determines what axle will fit. Are there no bike shops in your area? Find one and take the wheel in. Special tools are beneficial.
http://www.parktool.com/blog/repair-help/hub-overhaul-and-adjustment
Sep 15, 2011 | Sachs The Ride
MTD YARD MACHINE SNOW BLOWER DOES NTO SHIFT INTO
Many times moisture attacks the hexagon shaft that the friction disc assembly slides on. It slides from side to side on the shaft to create Reverse 1 & 2, and the other end creates 1-6 forward. With a wire brush and sandpaper, clean the rust from the hexagon shaft, at the same time lubricate the friction disc bearing with penetrating oil and with a soft hammer, tap gently until the assembly starts to slide on the hexagon shaft. After all the rust is removed and disc assembly is sliding, apply a light film of graphite grease on the shaft. You may want to re-lubricate on a yearly basis.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Jul 09, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
CHANGING REAR BRAKE
For rear pads rear rotors changing procedure you need lift up car,secure front wheels, disconect rear wheels from rotors,(if you missing the bolts try drill it whith portable electric drill at first smal drill 3 mm diameter,then 10 mm diameter.)Disconect the hydraulics breake cylinders cearefully putt it on plate not tears the house.Change beake pads.Unscrew the rotor whith hexagonal wrench.Setup the hand bracke clearance.Putt agan the rotor on rear axis.Assembly the breake cylinders ,and wheel tighening 110 Hm.
Mar 07, 2009 | 2005 Mercedes-Benz Mercedes Benz E320 Cdi
Rear axle berrings
Tools needed- typical socket and ratchet set, Axle slide hammer, Wiz Wheel type rotary cut off tool, chisel, ball pein hammer, hydraulic press, bech vice
First you must remove the rear wheels, then you must remove the brake capiler and mounting bracket, remove the brake rotor. unbolt 4 nuts on back side of brake dust shield that hold the seal and bearing securly in place. then you must attatch the slide hammer to the axle shaft by using the vehicles lug studs and lug nuts. use the slide hammer to knock the axle shaft out of the housing. it generally takes about 10-15 hard slams before it comes loose. once axle shaft is free to come out remove the slide hammer and pull the shaft from the axle tube. place the axle shaft into a vise and use the cut off wheel to cut off the bearing spacer. cut parralell to shaft until you hear a snap sound once it snaps use the hammer to slide the spacer off the end of the shaft. next you need to cut the bearing off the shaft using a the same technique being careful not the cut the shaft or the seal retainer plate. once the bearing is off then you can slide off the old axle seal. now slide on a new axle seal, axle bearing, and bearing spacer. take assembly to a hydraulic press and press the spacer and bearing onto the shaft until it seats squarely and make sure its all the way down onto the axle shaft. lubricate bearing with gear oil. and install shaft back into axle tube making sure that the recess in the seal retainer plate lines up with the abs sensor wire. tighten all nuts evenly top off gear oil
Dec 27, 2008 | 1999 Jeep Grand Cherokee
Broken plastic gear tooth - Fellowes P55-C Shredder
I suggest using Belzona (metal compound). Mix it with its hardner, paste it over the broken gear (dont worry if it gets over a couple of other gears. Let Belzona sink and dry (4-5hours). Get a Dremel drill with a fine blade on it and cut accurately where the teeth are meant to be. Voila, you have fixed your gear.
Sep 13, 2008 | Office Equipment & Supplies
Need to change tumble belt
REMEMBER TO UNPLUG BEFORE STARTING ANYTHING!
To do the belt...
3. Open the top of the machine - see the sides of the lid about 10 cm from front, remove plastic caps on each torx head, undo torx. (torx set required)
If you see a broken belt then remove it and re-order one from hotpoint...see http://www.4hotpoint.co.uk/cgi-bin/product.pl?PID=634224&brand=&model=wd64&part=belt.
6. to replace belt - see motor shaft at bottom of unit. Dangle new belt round shaft of motor and gently pull so it does not come off motor.(This is not easy!)
- If the belt is not broken in your case - it could be the brushes on the motor - I can give you info on this if required!
Please dont forget to rate me as fixya.
Jun 17, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Royal shreader pcua-29053u Damaged Gear
call royal spare parts department at 1800-222-2310 they will ship you a gear for about $6 + shipping
Apr 16, 2008 | Royal 10X Shredder
Hotpoint aquarius wma50
You should be able to do both without disturbing the motor.
To do the brushes - about half an hour...
3. Tip the machine carefully up so you can get to the underside
4. Pull cables off the existing brushes.
5. Remove the brushes with a cross head screwdriver. Each brush as two screws holding in on, but the brushes are keyed into the motor chassis. They are fiddly.
Mar 13, 2008 | Hotpoint WMA50 Front Load Washer
437 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
midnightmove
Level 1 Expert
quennie732
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
