Power outage occurred and when power came back on, the magnetron fan on the right interior keeps clicking and making a noise like it is trying to turn on.
SOURCE: Fan
spikes in line after power out can damage wierd parts...the microprocessor tells the fan to turn on when start is pressed...it sends a positive voltage to a transitor which saturates acting like a switch,,,I bet this transitor is shorted. good luck
SOURCE: The display is flickering and
The timer control board is getting short.There are many tiny electrical components on this board.Due to power surge ,one of the component or may be few more components got shorted and this is casing the control panel to flicker.the control board needs to be checked and this faulty component has to be checked and replaced. In some cases the board gets shorted out,if this happens.------------there is online site dealing with this flickering display.They inspect the board and replace the faulty component on the board,and make the same board working for you.In in case board repairing is not possible then you will have to get the control board replaced.-----------Click this link directly for online repair center of flickering display repairs:---
http://031d26d.namesecurehost.com/mwd/index.htm
If in case the board is not repairable then for getting new board.
You can get required
parts from sears part direct online site or from repairclinic.com site. -------- This will help. Thanks. Helpmech.
