Question about Crosley Set of 2 School House Bar Stool in Vintage Mahogany Finish with 24 Inch Seat Height - Furniture
How do I get the side pieces to fit?
I've tried reversing right and left but neither way fits flush like the manual says
Posted by Moria Coker on
whirleydoo
    Habit-Forming:
  • 25 Answers
Where is the trailer light fuse
The answer to this question depends on several factors such as: Whether the towbar was a factory fitted unit fitted during
pre-delivery, a genuine brand unit or an aftermarket unit & who, where & when it was fitted...
The majority of towbars & the assosiated wiring out there are simply wired in to the rear tail light circuits such as:
  • Trailer stop lights wired to vehicle stop light circuit in eighther of the rear tail lights.
  • Trailer park lights wired to vehicle park light circuit same side as the stop lights, as above.
  • Trailer number plate lights wired to vehicle park light circuit same side, as above.
  • Trailer reverse lights (if fitted) wired to vehicle reverse light circuit same side, as above.
  • Trailer left hand indicator wired to vehicle left hand indicator light circuit
  • Trailer right hand indicator wired to vehicle right hand indicator light circuit.
This means that if fitted in this manner (as the majority are) the corrosponding vehicle light fuse will affect the trailer lights unless the is an inline fuse fitted to each single circuit (which cld be blown). This is very uncommon & wld be a costly way to do it...
In some more modern cars that came from the factory (not the dealership ie. pre-delivery) with the tow bar fitted as standard equipment it is possible that there cld be a sepparate little fuse box or section in the main fuse box (the position of the fuse box/es shld be in your owners manual usually Under the bonnet, under the dash or behind font foot kick panels, & if you dont have an owners manual for your vehicle they are usually available to buy an aftermarket version or these days on the internet & often downloadable for free or @ a small charge).
All the best & I hope this is of some help...
Referances: Me, I am an auto mechanic.
Jul 01, 2014 | 2006 Jeep Grand Cherokee
I had a paper jam in my ESP 5200 printer. Now I can't figure out how to get the light gray back piece back into the printer. There are no pictures for how it fits. HELP!
Good Day Auntbigsis!
The gray piece at the back is the cleanout assembly.
To Install the cleanout assembly back at the rear of the printer after removing paper jam, just follow the procedure:
  1. Insert the right side of the cleanout assembly into the back of the printer so that the tabs fit into the slots on the right side of the cleanout area.
  2. Rotate the left side of the cleanout assembly until the latch snaps into place.
  3. Pull on the cleanout assembly to insure that it is seated.
Jun 28, 2011 | Office Equipment & Supplies
Have fitted new fluidmaster flush valve, has a dual flush button operation but water constantly dripping down bowl so fill valve activates sporadically to maintain water level. how can i stop water...
Flapper not seating properly,either get new flapper or try a old trick i've used shut off water to tank and drain tank then add hot water to tank and let set for a while sometimes that will soften and seat flapper it's worth a try it's free.
Jun 08, 2011 | Fluidmaster & Fits-All Faucet Connector
Kohler 1-piece flush valve seal replacement.
That is a tricky one. Tighten the tabs, twist into place, then tighten a bit more. They are a pain in the a$$, but with patience you will get it done. Good luck
Dec 28, 2009 | Kohler K-3489 Cimarron Comfort Height...
Removing arm on#88592 to stick thru side of tank
If you are referring to the flush knob, the nut is reverse threaded. Remove the nut, then swing the arm to the left, and pull straight out of the tank.
Dec 23, 2009 | Fluidmaster Plumbing
Holden commodore vz acclaim my06 remove front headrests
push in the button on the left headrest post and use a small piece of coathanger wire and do the same to the other headrest post. There is a small hole in the side of the plastic. Now pull up on headrest whilst doing this and it should come out.
Jul 08, 2009 | Baby Gear
I cannot remove the plate to pute the other plate on
Here's a copy of the manual instructions...
Detail Sanding
Your tool is equipped with a teardrop base which allows you to use it on large flat surfaces
and tight spots or corners.
The pad tips may wear unevenly, depending on use. The pads are designed to allow you to
interchange and /or rotate the diamond tip.
Fitting Sanding Sheets ( Fig. 2)
• Detach the two diamond-shaped tips from the sanding sheet.
If this doesn't provide enough information, take a look at the pictures in the manual at the following link: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/589307-02,MS550GBMS550GH.pdf
If you still have difficulty getting the base off, write back and let me know specifically what the trouble is and I'll try to help you with it.
• Hold the tool with the sanding base facing upwards.
• Place the sanding sheet onto the sanding base.
The diamond-shaped tip can be reversed and replaced when worn.
• When the front part of the tip is worn, detach it from the sheet, reverse it and press it onto
the sanding base again.
• When the whole tip is worn, remove it from the sanding base and fit a new tip.
Tip of the Sanding Base ( Fig. 3)
When the sanding base tip is worn, it can be reversed or replaced.
• Remove the screw.
• Reverse or replace the worn part.
• Fit and tighten the screw.
Finger Attachment ( Fig. 4)
The finger attachment is used for fine detail sanding.
• Remove the screw.
• Remove the diamond-shaped tip holder from the sanding base.
• Fit the finger attachment onto the sanding base.
Contour Holder Attachment (Fig. 5)
• The contour sanding pieces are for sanding curved surfaces and grooves.
• Remove the screw.
sanding base.
• Fit the contour holder onto the sanding base.
Fitting and Removing a Contour Piece (Fig. 6 & 7)
• Choose the contour sanding piece profile most suitable for your application.
• Place one end of the contour sanding piece into the recess at
the front end of the profile holder.
• Push the other end of the contour sanding piece until it clicks
into place.
To remove the contour sanding piece, push it forward then pull the rear end out of
the profile holder (fig. 7).
Fitting a Sanding Sheet Onto a Contour Sanding Piece (Fig. 8)
• Align the sanding sheet with the contour sanding piece.
• Press the sanding sheet onto the contour sanding piece, making
sure that the sanding sheet follows the shape of the profile.
Mar 23, 2009 | Black & Decker MS550GB Mouse 5 Amp Detail...
Radiator
check the "tightness" of the fitting. if i remember right its a flanged fitting. or a oring type. just remove it and check for the type......jimmy
Sep 23, 2008 | 1999 GMC Sierra
Fitting our LG LFC22740 refrigerator into our 33 inch space
If it doesn't fit, it doesn't fit. Period.
Sep 09, 2017 | Refrigerators
Crosley Set of 2 School House Bar Stool in Vintage Mahogany Finish with 24 Inch Seat Height - Furniture Logo
761 people viewed this question
Top Crosley Furniture Experts
Tom Chichester
ray gallant
Are you a Crosley Furniture Expert? Answer questions, earn points and help others
