Panasonic SA HT1500 DVR recorder...cannot erase recorded programs.
Have tried erasing various programs and none of them can be erased. I will appreciate any advice. I don't want to wipe the whole drive.
Posted by Donald Sosin on
Dan Castro
    Champion:
  • 329 Answers
On my DVR there is a "protect" option that will prevent me from deleting a recording. You have to press the "protect" button again to unprotect it.Once unprotected you should be able to delete the recording.
Posted on Feb 16, 2016
4 Related Answers
Anonymous
  • 59 Answers
SOURCE: Dish DVR
try this website http://satellitetv.digitalinsurrection.com/dishnetwork/dish_network_pvr_upgrade.php
Posted on Nov 14, 2007
Jim Franks
  • 374 Answers
SOURCE: Timers & recorded events erased
Ocassionally these receivers have been known to do this. It is not an issue that normally repeats itself however it is very frustrating. The upside is it ussuaaly will result in 150 hrs of record time. If you did not receive the150 hrs delete all timers and recording and reboot the system. You should have the 150 hrs once it comes back online. Thanks for using Fix Ya.
Posted on Aug 15, 2009
Anonymous
  • 7 Answers
SOURCE: Can I do a low level format on my DVR because it
This could not be the hardisk, it could be the main hv capacitor on the psu if your dvr has same psu as the thomson dt16300?
Posted on May 01, 2010
Testimonial: "Thanks. I'm not sure what it means exactly but I appreciate the response. "
  • 6224 Answers
SOURCE: dvr will not record. i get the message, " hard
You can erase the contents of the drive or set the drive to overwrite when full. Erasing the drive is the equivalent of reformatting (you will not be able to recover the images easily).
To Erase/Format, enter the Menu system and select Hard Drive Setup (seventh line in the list). Press Enter, then go to HDD Format (fourth item in the list) and press Enter. Then enter your password (set up under System Setup) but the default password is 111111, if it is on. If you entered the correct password, the screen will flash HDD Formatted 3 times. Press Menu to exit the menu. (If the incorrect password was put in, Incorrect Password will flash.)
To overwrite, again go to Hard Drive Setup then select the first item, Drive Full. Press Enter to toggle Overwrite On or Off. You will be able to recover the images until they are overwritten.
I hope this helps.
Posted on Oct 14, 2010
Samsung hdd recorder, I can't see my list of recordings. Please help, these are treasured memories.
Many software products attempt to aid you in recovering recordings, files, and data, but no guarantees.
There are also professional companies that will try for a fee - such as Ontrack.
Here is software you may want to try:
https://www.easeus.com/storage-media-recovery/recover-deleted-erased-cctv-dvr-videos.html
CCTV DVR Hard Drive Recovery Recover Deleted Erased CCTV or DVR Videos
Jun 16, 2018 | Samsung Televison & Video
My Panasonic E55 is having problems reading disks after I try to erase something on them. I erase without success and then it tells me the disk is unformatted. Also will not format disk after that. I...
Sorry this isn't a solution, but I just want to commiserate with you. I am having the same problem. I guess the problem started about three weeks ago. The recorder will not recognize any blank DVD-R discs and it only recognized 1 out of 4 new DVD-RAM discs. It would read most of my older DVD-RAM discs but would refuse to erase some of the old recorded programming. It also refused to recognize some of the older DVD-RAM discs, so in frustration I reformatted one. I was able to record and watch a couple of shows, but now it is saying "Unformat" for that disc.
About a year ago, the DVR gave ma some trouble and I was able to fix it myself. (I think it suddenly wouldn't power on, but I don't really remember if it was that or if it was a "SELFCHECK" error.) I had to open up the case and replace two capacitors. I bought the replacements at Radio Shack and my son helped me solder them on. My next step with this DVR will be to open up the case and look for any obvious problems. The worn-out capacitors looked oily and damaged, as I recall.
Sep 16, 2010 | Panasonic DMR-E55 DVD Recorder
Pioneer DVR-530H-S having erased a recorded program can it be recovered
dear madam,
i have DVR-530H-S my file have erased a recorded program can it be recovered, how to make it... very important for me...
or please call +62 8040-727-69
email : [email protected]
please call me after your post to email
thanks before
joko sudaryanto
Jul 20, 2010 | Pioneer DVR-530H-S DVD Player/HDD Recorder
Erase recorded files on my Cenix VR-P490 voice recorder
You have to select the file to erase hold the erase button and when "ERASE" blinks in the display you have to press the erase button one more time. Do this for each file you wants to erase.
Jan 20, 2009 | Panasonic RR-QR150 Digital Voice Recorder
How to erase recordings on the Panasonic RR-US500
I called the Future Shop where I bought the recorder and the salesman looked at the manual online and saw that the Delete instructions do not tell you what you need to know.
To Erase or Delete recordings from this recorder, you have to select the track or file you want to erase, hit the Erase button, see that track number flashing THEN hold the Erase button down for a full second.
You can toggle until ALL comes up and then erase all your files at once if you wish.
You can also hit the Erase button first and then select the track you want recorded. The important thing to know is that you then have to see the number flashing THEN hold the Erase button down for a full second.
Mar 29, 2008 | Panasonic RR-US500
Recording
I have the same problem. I believe this unit is a lemon by Samsung. I was so exhausted I went to Hard drive erase. After I erased the HD, now it will not record or go into recode mode. I think all it good for now is just to view the monitor. When I call Samsung they dont have a clue what a DVR is. I never seen a company so illerate. They cant even tell me where I can send it for repair.
Feb 12, 2008 | Samsung 4 Channel Dvr
Playback of recorded programs
try formatting the disc. it will erase everything on the disc and you can start fresh. try this with all the discs.if the problem keeps happening, try new discs.
wg
Feb 03, 2008 | Panasonic DMR-ES20EG DVD Recorder
Televison & Video Logo
169 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
