Question about HP Officejet Pro 8600 e-All-in-One - multifunction fax / copier / printer / scanner color
EATS PAPER PAPERJAM - HP Officejet Pro 8600 e-All-in-One - multifunction fax / copier / printer / scanner color
Posted by Sam Nelson on
303 Electronics
  • HP Master
  • 345 Answers
Try this fix. It is an upgrade model from 8600, but the build is same and rollers are located in the same spots.
Posted on Feb 04, 2019
Danny Kuhlmann
  • HP Master
  • 1,443 Answers
Sounds like either your pickup or feed rollers are bad, clean them with alcohol, if that doesn't work replace rollers or you have a controller board problem, needs to be serviced.
Posted on Dec 04, 2015
Paperjam siplay no paper in the back
hi open your printer so that you can see the wheels that feed the paper into the printer and check that no paper is stuck in the meconisom is this is soum times wey it says paperjam
Apr 09, 2014 | Kodak ESP 3 Multifunction Printer/ Copier/...
Paperjam for no reason
Clean the rollers with Windex and a lint free cotton cloth.
Jun 25, 2010 | HP 920 Plain Paper Fax
Paperjam J3203 and J7540.Konica Minolta Bizhub pro C6500
Pull out the paper carefully and next time use atleast "20 lb. paper" 24 lb is better.
Jun 08, 2010 | Office Equipment & Supplies
Paperjam in hp 1000 printer
two reason in paperjam 1200 series printer
one some senser not working so remove back sight cover and clean dust help with air blower.
and paper pick roller is not working
first you remove paper pick roller
and change direction of paper pick roller
means change direction means just opposite site use.
i think solve your problem.
Apr 10, 2010 | HP LaserJet 1200 Printer
310, 311 318 paperjam can not find it
is the paper in the fuser, try turning the fuser, sometime there are some small pieces of paper stuck in between the fuser and pressure roller
Feb 18, 2010 | OKI C3200n Led Printer
Printer epson r230 paperjam
Indikator paper jam di status monitor bisa berarti benar-benar paper jam atau carriage problem. Coba dibongkar dulu printernya, mungkin ada sesuatu yang nyangkut pada paper feeder, bersihkan sekalian paper sensor pada paper feeder. Kemungkinan kedua adalah problem pada carriage atau bisa jadi pada chip di ink tank. Coba dulu ganti chip pada ink tank dengan yang lain ( yang baru atau yang arc). Salam dari Arema
Dec 29, 2009 | Epson STYLUS R230 InkJet Photo Printer
CLX 2160 - paperjam
There is probably a jam in the paper feed area. Pull the paper tray out and stick your hand in to find and remove any paper stuck there. Then reinstall the paper tray and open and close the front door of the printer. The jam should be cleared.
If it is still showing paper jam, pull the tray out again and look to make sure you didn't miss any paper, then check the other areas of the printer (starting with the exit area) for paper.
Oct 24, 2009 | Samsung CLX-2160N All-In-One Printer
My printer says there is a paperjam but I don't see a paperjam.
its a mechanical problem ...
check the rollers of the printer ..and the paper pick mechanism ..maybe it can't caught the paper in the tray that why it display an error of jammed..
May 24, 2009 | HP DeskJet 3653 InkJet Printer
Kyocera paperjam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 02, 2009 | Office Equipment & Supplies
PaperJam
I found that the little plastic hinge guide that supports/aligns the scanning area with the printer (stage 4 on the internal paper jam problem) was misaligned. I just removed it and the printer now works OK
Aug 28, 2008 | Samsung CLX-2160N All-In-One Printer
HP Officejet Pro 8600 e-All-in-One - multifunction  fax / copier / printer / scanner   color Logo
70 people viewed this question
Ekse
efs_perpends
efs_perpends
