Question about LG LMV1683SW
Can the turntable be stopped
Can the turntable feature be stopped for a large dish
Posted by Bonita Lohman on
How can I keep the turntable from revolving when using a dish that is too large to turn?
Try removing the M/W turntable and placing a shallow bowl upside down centered over the rotating device. Then place your plate on top of the bottom of the bowl. The device will still rotate but will not be in contact with anything.
Nov 21, 2015 | Kenmore Elite Black 1.5 Cu. Ft. Convection...
Opened door ,oven light blew out,turntable motor stopped also noticed power button next to timer button shows nothin when you try it. but you can put in cup of coffee it will heet up.
This is a fairly easy one. First, make sure the turntable coupler under the glass dish is not broken. Second, on the control board, find the turntable relay and test for voltage. Some turntable motors are 24 volts DC, so make sure your testing the correct voltage. If no voltage from the control board, then replace the control board. Otherwise head towards the turntable motor.
On OTR models, you can get to the motor by un-screwing the bottom panel on the microwave. On countertop models, there will either be a knockout or screw on access panel. Check for voltage at the motor. If no voltage, check the wiring back towards the control. If voltage, then replace the turntable motor. The component list below also shows how to test a turntable motor.
Apr 02, 2013 | Microwave Ovens
Turntable stopped rotating. Everything else works fine.
It sounds like the turntable motor has failed. It is a synchronus motor with a plastic gearbox reducing the RPM to about 5. The gears fail when the turntable dish is turned as the motor stalls the shafts.
Replacing the motor is no big deal.
There is usually an inspection cover that can be removed on the underside of the cavity.
Remove the cover and remove the motor.
Replace with the same type and the reverse procedure will fix it.
You may however require a self tapping screw to affix the cover back on. A bit of a puzzle but not too difficult to work out!
Hope this helps.
Nov 29, 2010 | Whirlpool MT4155SP Microwave Oven
Turntable doesn't rotate
Your turntable motor need replacement. tip upside down with dish removed and gain access to turntable motor from underneath.(remove power plug before you start working on the m/wave.) 2 screws hold the small t/table motor in place.Unscrew both and pull motor upwards. Quote the info on the motor for a replacement. I find cooking isnt effected in any wayexcept if you want to bake things like cakes. It then requires the t/table motor.
May 21, 2010 | Panasonic NN-T993SF Microwave Oven
this microwave has a turntable motor that can be accessed from under the micro.. usually a $15-30part.. put your modle number on partsdirect.com and you can see how it comes apart
Feb 28, 2009 | GE JVM1651 Microwave Oven
The glass dish that goes around - makes a strange noise
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
You may have a bad motor orplastic coupler.
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
Nov 22, 2008 | Kenmore Microwave Ovens
I own a Advantium 120 Oven. I love my microwave however there are times that I need to stop the turntable in order to reheat or cook something in a casserole dish. How can the turntable be turned off?
I guess my problem cannot be fixed. I was told that my microwave turntable is automatic and cannot be turned off, therefore, if you have a 9 1/2 x 11 dish and need to reheat something it cannot go in the microwave because it does not fit .
Aug 26, 2008 | Microwave Ovens
Tray
The most likely causes are a bad turntable motor, a bad turntable coupler, or a problem with the wiring to the motor or on the controller. Also, you might check your manual to see if there is a feature to turn it off. It may be set to off. You can find the owner's manual online here: http://panasonic.com.au/content/library/files/F001226.pdf or http://manualshark.org/manualshark/files/24/pdf_17508.pdf You can get any needed parts here (enter your model number without any dashes) http://www.pasc.panasonic.com/epartr If you need more help, please reply back. I appreciate your thoughtful rating of my answer.
Oct 05, 2007 | Panasonic NN-MX26 Microwave Oven
LG LMV1683SW Logo
260 people viewed this question
Top LG Microwave Ovens Experts
Sheldon Dedek
Randy Schumann
Randy Schumann
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
