Question about Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
I have a sony bravia tv 52" power on and off ok,I have green light but no picture,no sound.All black screen.
I just replaced new power supply board from Shopjimmy but it still does'nt work, I had tried out flash light test and I saw only dark screen.Please help me what's the problem.Thank you.
Posted by Quang Dang on
    Top Expert:
  • Sony Master
  • 76,407 Answers
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Dec 03, 2015
I have a 32" Samsung LED TV with not picture. Audio is working.
Do flashlight test - if you can see image you need t con board. If no images seen, inverter board. TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 18, 2017 | Samsung Televison & Video
My tv flashed on and off and left with 6 blinking lights. Did a power reset and tv powers up with Sony on the screen then goes dark but the green light stays on. Screen is dark. Which panel is bad.
Probably the back light inverter is faulty . Before going to buy a new inverter board tey to check the power supply. Which the bellow added video to know how to check a power supply board. You have to check the 24V power sto the inverter board from the power supply. if its not there then the problem is with power board. If its ok then you have to go for a new inverter board. Also try to replace the electrolytic capacitors in the power supply board. some times bad electrolytic capacitors can lead to back light failure.
www.electro-medical.blogspot.com
Testing LCD TV Power Supply BoardsSTEP BY STEP
Oct 31, 2015 | Sony Bravia Kdl-46bx450 46" Class 1080p...
I have a hisense 55" tv the screen is really dark but is still working knowing because I did the flash light test. Would it be my power supply panel
If the back light inverters are mounted on the power supply board, then yes, the power supply board needs replacing. If the inverters are on a separate board, then replace that one. Use a voltmeter to check if the different voltages produced by the power supply are present and within +or- 5% of the expected voltage.
Sep 28, 2015 | Hisense Televison & Video
How Do I repair my LG LED TV that does not power on?
If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
You can repair it very easily, within seconds.
Sep 16, 2015 | LG Televison & Video
No power and no glow to the screen. I'm assuming a power supply problem and I'm looking for a tear down of the unit. I also understand there are some fuses inside the case as well. Visual...
U have power to the tv is that correct?Yes?Power led light indication solid green,when tv is on but u have a blank screen no picture to the LCD screen panel at all?Yes?Than this problems it is not the tv power supply board problems.The tv Tuner signal board is it the cause and the problems.That the board where the incomming broadcasting signal cable plug into it.This board are 90%-95% are not repairable or troubleshoot able,because it almost all micro components parts and micro chips and most of them are surface mounted it on.This tv Tuner signal board can be only replaced with a new whole refurbish one only.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Aug 11, 2011 | Insignia NS-LCD47HD-09 47 in. LCD TV
My proscan TV was working fine. then the video went and now no audio.. it lights up briefly when u turn on. then screen goes dark.. is this fixable or better to get a new tv..It is only 3 years old
I believe it's fixable! Take a look on your video and audio cables (behind the TV, the red, yellow and white ones). They must have a problem. Already happened to me!
I hope I've helped...
Feb 14, 2011 | Proscan 42LA45H 42 in. LCD TV
16" lcd new out of box flashing blue light on power indicator
Under a year old tv?This tv have power supply problems.Call the for warrenty repair.Or tries websites like shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jul 14, 2010 | LG 32LG30 32 in. LCD HDTV
Viewsonic N3250W I replaced the power supply board but when I turn on, the screen flashes real quick and there is no picture.
it was not the power supply its the invertor board that controls the back lighting/switch on screen flashes lights go off/shine torch into screen ull see picture/get new invertor board 7 or 8 little plugs go into it
part or repairs in uk ohm supplies
Jan 08, 2010 | ViewSonic N3250W Television
Sony BRAVIA KDL-52W4100 52 in. LCD HDTV Logo
193 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
