Question about Precor EFX 546i Elliptical Version 4
How to fix resistance stuck on high?
The resistance on my elliptical is stuck on high. The machine works and turns on, but is very difficult to operate, I need to be able to adjust resistance.
Posted by Matthew on
1 Related Answer
Anonymous
SOURCE: the resistance on my Precor elliptical 5.17 will
There is a small motor under the shroud that operates the resistance motor. It is about the size of a roll of half dollars. Have someone use a meter and check that you are getting power to this. When you turn on the machine the motor should move the resistance forward then back. You can hear this everytime you turn it on.
Posted on Mar 11, 2010
Precor elliptical says stuck key on upper display and sometimes flickers or doesn't even turn on at all.
A stuck tek generally means the hard overlay (with buttons) is faulty. I have seen where the entire console needed to be changed. The battery may have also been bad but this would have been for the flickering only.
877-805-1030
Book An appointment
Mar 09, 2016 | Exercise & Fitness
Why is the the resistance on my sole e55 remaining easy to spin regardless of which resistance setting I select?
Belt could have come off. if the belt did break or come of it would be very easy to spin pedals. Flywheel ( brake ) could have jammed up. Loosen the covers and look for the brake cable that's connected to the resistance motor. Then run the resistance up to 20. If cable feels loose , the brake is stuck. Sometimes you can pull on the cable and it will free it up.
Aug 30, 2014 | Sole Fitness Sole E55 Elliptical
How do I adjust the tension. Even at zero resistance it is too difficult
Hi Doug,
You may have a problem with the resistance motor. The covers will have to be taken off to fix.
Usually when you increase or decrease the resistance you will hear the motor working. Do you hear it ?
Nov 03, 2013 | FreeMotion 570 Interactive Elliptical
My digital screen on my 420 elliptical schwinn blinks on and off
replace batteries and proceed with this steps and fix it. God bless you
Check power problems if the console on the elliptical machine does not light up. Make sure that the plug for the machine is secure in the outlet. If it is plugged in, ensure that the outlet is receiving power. Check the breaker to make sure it has not tripped off.
Be sure that you are using the correct adapter that came with the elliptical machine. Because different adapters are able to handle differing amounts of energy, the wrong adapter will not transfer electricity like it should. If the adapter is pinched or damaged, this could also alter its effectiveness.
  • 2 Make sure the correct adapter is being used if the resistance settings seem to be too hard or too easy. If the correct adapter is being used, reset the machine. To reset the machine, either switch the "On/Off" button or unplug the machine from the wall. Doing this will allow the device to reset itself to the default resistance. Turn on or plug the device back into the wall and retry all of the levels of resistance.
  • Read more: http://www.ehow.com/how_6149016_troubleshoot-elliptical-machine.html#ixzz2gVxyHBXj
    Oct 01, 2013 | Exercise & Fitness
    Life Fitness X3 does not turn on. So I can't set resistance nor intervals with console. Plug was checked and is fine.
    follow this steps and fix it.
    God bless you
    • Check power problems if the console on the elliptical machine does not light up. Make sure that the plug for the machine is secure in the outlet. If it is plugged in, ensure that the outlet is receiving power. Check the breaker to make sure it has not tripped off.
    • 2
    Sep 30, 2013 | Life Fitness X3 Elliptical Cross-Trainer...
    Bladez elliptical
    see the steps and fix it. God bless you
    Adjust the magnet with bolt attached there are loose, tight very well and ready the resistance is the main parts that need repair,
    However if the resistance is faulty, you must test again the magnet from the refrigerator by attracting or repeled, if do not pass this test replace it buying small cheaping from home depot or similar.
    GoD BLess you
  • 1 Check your owner's manual for diagrams and definitions. You'll need this information when you put the elliptical back together. You'll also want definitions in case you need to call the customer support line for assistance.
  • 2 Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced.
  • Sponsored Links
  • 3 Consider that if the foot pedals are attached with bolts, any slipping can be fixed with a quick use of the wrench. But if the foot pedals are damaged or breaking, order new foot pedals (see Resources below) rather than run the risk of a pedal breaking while you're on the machine.
  • 4 Check the hand bars. While not all people use them, as they can elevate your heart rate by up to 20 percent, they can become worn, too. While loose hand bars typically need a simple tightening of the bolt, be sure not to overtighten as the bolts can break.
  • 5 Know that if the axis is bent, it's likely you need a new machine. The axis is the central alignment of the elliptical. If the machine was used by a person who is over the maximum weight limit, it can be bent or damaged. It's not an easy fix and a better idea is to upgrade to a sturdier machine.
  • Read more: How to Fix an Elliptical Machine ' eHow.com http://www.ehow.com/how_4681374_fix-elliptical-machine.html#ixzz2DLrv9YSH
  • Sponsored Links
    Nov 25, 2012 | Bladez X350P Elliptical
    How do I fix my crosstrainer, magnetic resistance has stopped working
    This happened to me and I took the wheel mechanism cover off to discover the tension motor cable had come out of it's pulley guide- so there wasn't enough tension left in the cable to pull it away from the wheel- quite an easy fix for me- hope it is the snake for you!
    Feb 15, 2012 | Exercise & Fitness
    The resistance on my Precor elliptical 5.17 will not increase. All other functions on the machine work. Any ideas?
    open shroud and find the circuit board unplug and plug back in all connection this may sometime clean any oxidation off the connector. this is what I've in their 546's should work on the 5.17
    Feb 28, 2010 | Precor EFX 546i Elliptical Version 4
    Resistance level does not change anymore. What is
    I fixed a problem with my Schwinn Elliptical 430 resistance level not working. When I would change the level anywhere from 1-16, I could hear the motor turning, but there was no change in resistance. If you hear the motor moving, then try this:
    Using a Phillips screwdriver, remove all the screws on the left side of the large plastic cover (left side if you are standing on the machine). When all screws are removed, you can pull the plastic cover off, and move it towards the back of the machine without having to disconnect any of the metal bars. (The bottom two screws are a little tricky to get off. Hold the housing in place, don't let it sag, in order to get them out.
    Look inside the unit and find the magnet, which is a rounded, brake-show like piece that is close to the flywheel, on the top half of the unit. There's a cable from the motor that goes upward and is attached to the magnet housing.
    If you try to adjust the resistance level now, you should see cable move up. This is supposed to allow the magnet to move closer to the flywheel and increase resistance. In my case, the magnet was stuck and wouldn't move upwards. When I gave the magnet a little push with a screwdriver, it popped up to where it should be.
    To solve this issue, you will need two wrenches. You must go to the opposite end of the magnet, towards the front of the machine, and you will see it's connected with a nut & bolt. Using a couple wrenches, hold the bolt, and loosen the nut about 1/4 turn.
    This should lessen the pressure on the magnet housing and allow it to move freely and not bind. Reassemble everything. Lie the elliptical down on it's side to allow the screws to fall into the holes easier.
    Once it's all back together, you should find that the resistance level works again!
    Sep 23, 2009 | Schwinn 430 Elliptical Trainer
    Precor EFX 546i Elliptical Version 4 Logo
    906 people viewed this question
    Top Precor Exercise & Fitness Experts
    NOEL
    NOEL
    Ngoro
    Andrew Taylor
    Andrew Taylor
    Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
