suleiman a azeez Posted on Dec 02, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to clear F2 error code in sharp AR 163 copier machine
Norman Weimar
Level 3:
  • Sharp Master 7,035 Answers
  • Posted on Jan 29, 2016
Norman Weimar
Sharp Master
Level 3:
Answers
7035
Questions
Helped
1910605
Points
11959
Replace toner cartridge with OEM do not use third party
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
4 Related Answers
checkitright
CheckitRight
  • 1363 Answers
  • Posted on Nov 20, 2007
SOURCE: copier sharp ar 163
check my site under error codes/Sharp
http://checkitright.spruz.net/main.asp?page=dp&dis=592197
Anonymous
  • 13 Answers
  • Posted on Oct 30, 2008
SOURCE: My Sharp AR-287 Copier is showing F2 error
there Should be 2 additional numbers. F2-??
san3409jl
  • 190 Answers
  • Posted on Jan 27, 2009
SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
Anonymous
  • 41 Answers
  • Posted on Jul 01, 2012
SOURCE: System error (f2-04) for Sharp Copier, model AR-M201
It is copy lamp error.
1- check the copy lamp on with sim.
2- replace the power unit.
3- replace the inverter.
4- replace the mcu pwb.
How to clear sharp AR 163 diplay f2 error code
replace the toner cart and drum 3rd party with oem
1helpful
I have sharp AR-163 it indicate f5 error. And Sf 2030 error code f2
Ar163 F5 = Copy lamp problem.
Possible causes are:
Blown Copy Lamp
Inverter trouble (copy lamp driver module)
MCU Board failure
This is most likely to be a blown copy lamp.
Ar2030 F2 is a process control error - depending on the sub-code it could be a number of different things. Please repost with the full code.
Hope this helps.
11helpful
2answers
Sharp AR-163 Copier, How to Reset/Solve the error Code U2-40
how to clear red sing on tonal problem for sharp ar 163
Code F2-04 solution
http://www.retrevo.com/support/Sharp-AR-M162-Multifunction-Printers-manual/id/600ag113/t/2/
Above is your user manual below is your service manual.
http://www.eserviceinfo.com/index.php?what=search2&searchstring=AR-162,+AR-163,+AR-201,+AR-206,+AR-207,+AR-F201
http://www.eserviceinfo.com/fulltext.php?search_ft=DPX-7010MD
You have a sensor error. I have included your user and service manuals so you can attend to the error.
F1-04 Bin limit position sensor error in sorter
Error f2-31 en fotocopiadora sharp ar 287
You must your copier TD cartridge,then solve your problem.If you are not fix it,Then press
C>Photo>C>photo>16> start key
Sharpe ar-163 with error code u-240
Hello sir; The error code you display is CRUM communication error.
16helpful
4answers
F2-02 Error on Imagistics ZB35 machine
Sharp AR-5620N getting f-2 error. What is the solution
Sharp AR-163 Copier
replaced your toner cartridge with a new one, if you install a new one and it didn't work and still F2 flashes, the cartridge that you buy is not suitable for your country, always ask for a genuine toner, do not use compatible toners for your copier.
67helpful
13answers
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
