0185,0188,0184,0183,0180. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order.Pull up older posts. Surf the site with patience. http://electro-medical.blogspot.com/ http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/
Access the help section of the menu on your uverse connected TV. Select the option "Remote Control Setup". Select your style of remote and select the type of device that you want to program your remote to and then just simply follow the instructions provided on-screen.
i currently use uverse and none of there remotes work for dynex tv's i suggest buying the logitec harmony 520 or 420 or above remote from amazon read the reviews there around 40 dollars and lets you control everything and they connect to you pc you just plug in you model number and the remote learns all the commands as well as lets you set up activities that will allow you to control multiple devices without having to switch between hitting the tv button, home theater button, uverse box etc. hope this helps.
ATT Uverse remote doesn't work well with Emerson TVs. Most will turn off with the correct code but NOT ON. Find the code that will turn OFF the Emerson TV.(volume should work too) When you want to want to turn ON your Emerson TV Try This (Believe it or not) Wave ATT Remote slowly and press ON in mid wave. The ATT remote on frequency must be slightly off. This works every time for me now that I know the secret. Remember Doppler Effect from High School Physics.
