Nothing happens when I press the power button. No light or sound. Already replaced the power supply board and its still not working. What else might it be? Main Board?
SOURCE: Westinghouse LTV-32w6 power light on, no video, no sound
One thing is to make sure the inverter board is unplugged when testing the voltages. A shorted inverter will shut down the power supply if the fuse dosen't blow first. There are fuses that don't look like fuses so they can be missed. The next thing would be to look for a connector from the main to power supply and see if there is a pin labeled power on or p.on or similar. The main board should turn this line high(5V) when you push the power button. If not you probably have a bad main board. Unless you can find good used boards they are both expensive. Around $200 for PS and $300 for main.
SOURCE: Vizio L37hdtv10a fails to fully turn on
You will have to isolate the main board and Inverters.
Unplug the inverters and turn on the set.
If it "turns on" then try re-connecting each inverter seperately to see if only one is causing the problem.
SOURCE: My VP504fhdtv10a vizio plasma TV when connect
Logic Control D Board got nothing to do with this problem. This is your main power supply gone bad(usually not the sub power supply). I just repaired my VIZIO by replacing main power supply. Just remove back cover and your board will be right in the middle of the screen. Just get board part/serial # and google it. My best price was through eBay(around $100). Everything is fine now.
SOURCE: Sanyo DP50747 Replaced Power Supply still not working
this issue is related to either the y sustainer and z sustainer boards, checking the fuses on the y/b will giving you a good indication, if they are open(bad) then you'll have a easy fix, if not, i would try replacing the y board first.
