I drained out the old gas&sit cranked & I rode it several times & then I went out 1day to ride&I cranked it and it run for a few seconds&it died & it hasn't started back up since then any ideas of what could be the problem with it? & this one is fuel injected so no carburetor on it!!!
Try running sea foam through ur system take the gas hose off the tank make a funnel system to that hose fill it with straight sea foam crank the bike untill it sucks at least 1 cup full let it sit for 24 hrs then try to start the bike with gas by adding through the funnel still no luck check spark plug for spark if no spark check sensors a wire could have croded and not making good connection also check your fuse box changing fuel pump could have blowen a fuse
Testimonial: "I haven't done the foam crank but I have done the spark plug and it does still get a spark and I ave also took off the cover around the fuel pump Bc it had trash in it at the bottom where the gas was so I cleaned that out poured new gas back in and it cranked back up I rode it back down the road and it spit and sputtered and went dead on me and I had to be pulled home and I have done that since I drained the gas tank and put in fresh gas. But I have never heard of or tried the sea foam through my system where would I find that stuff at??? & Thanks so much!!!"
Sea foam is at any auto part store and walmart there is a good video on you tube how to do it I'm almost certain that the jets are cloged once you get it cleared out just rember to un hook your gas line run the bike dry and empty ur tank if ur going to store over 1 mounth
And that is on a fuel injected one also right Bc that's what this one is? Sorry I have 2 & I just don't wanna tear anything up any worse is all so that is why I ask so many questions my apologies. But I do thank you for your help.
Yes this works with all fuel injected and carbrated engines cars trucks lawnmowers its the best thing sence wd40 works in the oil also stops sticky rods when they are tapping
Please ask all the questions you can its better to know then not
