you will need the complete model/serial number for proper part#. To locate which fan is problem try watching to see which one is not coming on at start-up.
Check the fans for dust and dirt if duirty clean them. If you do not see any that are dirty then it means Fan is defective if it stops running while set is trying to come on.
Samsung Parts.com 1-800-627-4368
Look at the Large Lamp fan and if it is not rotating it is bad and needs to be replaced. If is ok then check the other two smaller fans. You do have a bad fan.
Defective Lamp,maybe and Ballast Board may well be the problem it is what turns Lamp on Look on line Encompass Parts Dist 1-800-638-3328 Ballast Board also has small fan mounted in front of it!
Their is no more you can do. You need a professional. Stop using the TV until it is repaired. Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc Milwaukee, Wisconsin 53405 (414) 762-8600 Established 1974
Since the lamp generates a lot of heat, the fans are continuously monitored for correct function. The owner's manual should show you the location of the fans. Make sure that the grills covering the fans are clear of dust and that the fans are clean. Sometimes dirt can cause the fan blades to slow down enough to trigger the safety alert.
