Texas Instruments TI-30XA Calculator Logo
Question about Texas Instruments TI-30XA Calculator
Screen comes on but some of the outline of the numbers don't show.
Posted by Debra Guevara on
TV Screen is orange
In order to TRY to assist you I need the brand and model number.
There's no icons,the wallpaper,screensaver don't show up
Hi there.
I would suggest running the last system software update, using your computer if necessary Sony have a support page outlining how to do this see the link
http://us.playstation.com/support/systemupdates/ps3/
I have a verizon LG droid touch screen phone, it got slightly wet last night and now I cant open the screen with my security outline, it rings with incoming call and shows txt coming in, but I cannot open...
Try this trick:
Get a bowl or container and a package of white rice(it has to be white rice, this will not work with brown rice).Fill the container with the white rice.put the cell phone in the container with the white rice. Leave the cell phone in the container of white rice for 36-48 hours. The white rice absorbs the moisture out of the phone.
Jun 23, 2011 • Cell Phones
I have a 61'' Panasonic tv that is showing green and red outlines around the figures on the screen. It originally started as just green outlines. Any ideas on what the problem is would be great. Thanks
The convergence is off. The convergence is basically the assimilation of the image on the screen from the three "guns" behind the screen. There should be a menu option to align the convergence in the image portion of the menu. If this does not fix the issue, then your convergence chip might be on it's last leg.
1helpful
Red & Green outlines but only on left/center portion of screen.
Its a convergence problem. You may want to check the site www.tvrepairkits.com. Every thing they said every description was right on. The best money I ever spent and the confidence you get from doing it yourself, Its a great feeling of achievement not to forget the live messenger support is instantaneous, friendly and informative if you need to fix your tv go to tvrepairkits.com I fixed a philips 60 inch tv in 45 minutes, The convergecne chips were bad thanks a million. You guys saved me 250.00 bucks. I'll be recommending you to everyone I know!
2answers
Getting double images on screen like outlines on images
Your TV has a failure of its convergence output ICs and perhaps some of the convergence circuit's other associated parts. The part numbers for the ICs are on the IC face. They can be purchased thru Hitachi or online at MCM Electronics.
1helpful
How do you turn a psp back on only the green light shows
Sorry about the problem you are having with your psp, meanwhile you can follow the simple steps that I'll outline below to see if the problem can be fixed.
Step 1. Switch off the psp and make sure it is not connected to any power source, then pull out the battery and fix it back.
Step 2. Switch it back on, and if it does show only the green light without having the screen come on, then i guess the screen could be damaged or other associated screen components.
Step 3. Don't open the psp because you are technical enough, please take it to a sony center closest to you and you'll have the screen changed or the associated component/componnts.
Regards
Having an issue formatting an outline in Microsoft Word 2003
Are you using styles? You could create a new style based on the existing style that has "Start at" and "1" as one of it's attributes. Then whenever you need to restart numbering, just apply the new style. Reply if you need help with styles
ANDIS GTO T-OUTLINER MODEL 04710
Please go to our website at www.andis.com. Click first on USA, then service, then use and care. Once you are at the use and care screen scroll down to GTO and click on the item number. The manual should then come up. If you have any further questions please do not hesitate to contact the Andis customer service department at 1-800-558-9441.
Thank you,
Top Texas Instruments Office Equipment & Supplies Experts
Filipe Polido
Filipe Polido
Muzahura Frank
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
