Question about Boating
I have a 1978 merc 85 hp outboard with a bad pump i purchased a used one that works mine has 4 hoses
I have a 1978 merc 85 hp outboard with a bad tilt pump i ordered another used pump it has two lines and mine ha 4 lines he sent an adapter to adapt the 4 lines to the 32 lines question is how do i hook the lines to the adapter
Posted by DAVID MICHNAL on
Claude Kayser
    Top Expert:
  • 9,098 Answers
Mercury Outboard Fuel Pump - Mercury Outboard Forums
forums.iboats.com/Mercury-Outboards/Fuel-Pump
5, 2004 Mercury 225 four-stroke EFI no power to Low Pressure fuel pump. Why please help · Mercury & Mariner Outboards. 13, Mercury 850 (85hp) - Gas pumps through the top carb - Failed fuel pump? ... 1, 1969 7.5 H.P. Mercury (Bad fuel Pump)? ... 1971 · 1972 · 1973 · 1974 · 1975 · 1976 · 1977 · 1978 · 1979 · 1980 · 1981 ...
Fuel Pump Diaphragm replacement Mercury outboard 110 ...
? 4:18
https://www.youtube.com/watch?v=vufekxTVZd8
Jun 22, 2012 - Uploaded by Brad Clark
My last test run of this motor lead me to believe I had fuel pumpissues...so in ... Mercury 9.8 h.p. 110 Outboard Motor WaterPump Repair and ...
How to remove the lower unit on a Mercury outboard motor ...
Posted on Dec 01, 2015
NEED IMPELLER KIT PART # FOR 2.5 LITRE V6 2 STROKE SERIAL NUMBER OD145403
available from any merc outboard service shop
if there is none close , the kit may be generic so mariner pump may fit
talk with outboard shop spares
Nov 15, 2017 | Boating
1978 175 hp evinrude outboard not fireing
Purchase a manual and go through the troubleshooting check list.
Sep 26, 2017 | HP Boating
What would cause no water to circulate on a 2 stroke Nissan 70h outboard. Just changed the water pump. And still nothing
On mine the hoses were plugged. It looked like white spider web material that came out. My Merc works now.
Aug 21, 2016 | Boating
What size and year is my mercury outboard serial n 5266428
It's a Merc 45 from 1978. Serial numbers 4869518 thru 5270783 are 1978.
Apr 30, 2016 | Boating
How to set timing on 75 hp johnson outboard
creates an impulse to the cid as a magnet passes by . not much adjustment to timing small screw toward the front that moves the stator perhaps a 1/4 inch .
Aug 17, 2015 | Johnson Evinrude Timer Base, 6 Cyl 75-85...
What size and year is my Merc outboard serial# 6181919?
Good Morning James,
From The No Given I get That It Is A 150Hp Mercury
Year Is Between 1978-1985
Regards
Gordy
Jun 11, 2015 | Boating
What pins on the ignition switch are energized when when you turn the key on a 2003 mercury 15 hp 4 stroke outboard?
Red is Battery +
Red/purple is ignition
Yellow/red is startermotor
Black/yellow is motor kill
Black is ground
To have ignition, black/yellow wire must be disconnected
On is red/purple on bat+
To start Yellow/red on batt+
To kill: black/yellow on ground
Jul 29, 2017 | Boating
I'm looking for a downloadable version of the service manual for this motor. Any Ideas? It's a 1994 mercury XRi 175 hp outboard
I couldnt find one anywhere for my merc 75hp 2stroke-ended up buying a service manual $70
Oct 09, 2009 | Boating
Merc outboard 115HP 1996 fuel primer/Choke
Hello there
here is a good place to start ok Outboard (wiring A Tachometer To An Outboard, Mercury Outboard Float) safe.gif
merc outboard motors mercury outboard ... diagram of mariner outboard motors johnson outboard fuel problems ... johnson outboard motors ebay 1996 115 hp mariner outboard
  • tipsterdatabase.com/mods.php?id=outboard
  • · Cached page
Aug 27, 2009 | Boating
35 hp merc
fuel pump reed valves bad gas tank or hose
Aug 12, 2009 | Raymarine St6002 Smartpilot Hydraulic...
Boating Logo
437 people viewed this question
Top Boating Experts
ray gallant
 vpsoccer
vpsoccer
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
