Question about Health & Beauty
How do I remove the seat to remove the battery?
Posted by bill marinez on
Scooter Doctor
    Master:
  • Health & Beauty Master
  • 401 Answers
Pull the lever and lift, or unlock the lock under front of seat and tilt back seat, or pull levers and tilt pull forward lift off, or flip lever in back and slide out, or undo front or back and slide out the batteries.
Make/Model PLEASE.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Posted on May 15, 2016
Remove battery
  1. If equipped with power seats, move the seat to the most forward and upright position.
  2. If equipped with manual seats, move the seat to the most forward position.
  3. Turn the ignition switch to the Off position. Be certain that all electrical accessories are turned off.
  4. Remove the battery cover (1).
  5. Remove the negative battery cable (1) from the battery.
  6. Disconnect the positive battery cable and position aside.
  7. Remove battery thermal blanket.
    1. Remove the battery hold down retainers (2) and remove the battery hold down (1).
    WARNING: Wear a suitable pair of rubber gloves when removing a battery by hand. Safety glasses should also be worn. If the battery is cracked or leaking, the electrolyte can burn the skin and eyes.
    1. Remove the battery from the vehicle.
Jul 12, 2013 | 2012 Jeep Grand Cherokee
Where is battery located
The battery is located underneath the rear seat , you remove the rear seat by pulling upward on front of rear seat. Pull up and out to remove it from the car. Next remove both cables, the black (negative) first, then the red (positive). Completely remove the bracket that holds battery. Remove the battery, be careful of any liquid and or wetness on the battery it is acid and will burn your skin and your clothes and carpet. Same directions in reverse order to install the new battery. Hope this helps Fix Ya up.
Aug 08, 2011 | 1997 Buick Riviera
How do I replace the battery on a 2001 Suzuki Volusia Intruder?
To replace the battery:
1- remove the rear (passenger) seat by removing the single bolt behind it. Remove the seat by lifting it up and back
2- Remove the front (driver's) seat). Remove the two bolts behind it and remove the seat by lifting it up and back.
3- Removing the seats will give you access to the battery under the driver's seat.
4- Carefully remove the positive and negative battery cables from the battery, then lift the battery straight up.
5- Place the new battery in the bike
6- Replace the cables, red is positive (+), black is negative (-)
7- replace the seats, and you should be good to go!
Apr 19, 2011 | 2001 Suzuki VL 800 Volusia
Where is the battery located? seriously?
Hi!
check under the back seat. Good luck
Jan 23, 2011 | 1995 Buick Riviera
How do I remove the seat to get to the battery to replace/re-charge the battery on my 2006 honda 650 vlx..?
The battery can be accessed by removing the right side cover and unbolting the smaller battery cover underneath the fuse box. The seat is removed by taking out the two bolts that hold it in place. I believe the two bolts are underneath the fender and go up into the seat You should not have to remove the seat to charge or remove the battery.
Dec 13, 2010 | Honda Vigor FX 650 Motorcycles
Remove battery
The battery is under the back seat. I stand in the middle of the back seat area and pull up on the seat to remove it. Then carefully remove the battery clamps negative first. Remove the battery hold down bolts and lift the battery out.
Sep 13, 2010 | 2000 Buick LeSabre
Drained my battery on a honda silverwing 2004 cant find battery compartment
UNDER SEAT
The battery is located in the battery box
below the seat.
Open the seat
Remove the screw then remove the
battery cover
Disconnect the negative terminal
lead from the battery first then
disconnect the positive ( ) terminal
lead
Pull the battery ( ) out of the battery
box.
http://www.silverwing.org/
Jan 24, 2010 | 2004 Honda Silverwing 600
Where is my battery
Most M/C have the battery located under the seat. Remove the seat and you will see the top of the battery.
May 08, 2009 | 2005 Suzuki Boulevard C50
Remove seat and battery Yamaha tw-200
There are two seat bolts under the seat that must be removed. Obviously, if the underside of the fender is covered in mud, you'll have to clean it first. A metric socket works best to remove the bolts.
After removal of the seat bolts, lift the back of the seat, then pull straight back; a plastic flange on the front of the seat hooks under the tank, and so you have to pull it backwards to remove it.
With the seat off, removing the battery is pretty easy. A rubber strap holds the battery down; unhook and remove it. Unscrew the lead wires and unhook them (negative first), then pull the battery out.
Install a replacement battery by reversing these steps. Yamaha recommends charging a new battery before installing it.
Mar 17, 2009 | 2001 Yamaha TW 200
How to remove seat to get at battery
from what i remember on mine, it did have to come off and what a bear it was to get the seat bolts to align properly during reinstallation.
remove the seat, remove the battery, install the new battery (but install a battery tender pigtail and route it down the side), install the seat (lightly tape the hex bolts to the hex wrench so you can stick them in the blind hole) and secure the pigtail to the frame. now when the battery gets low, the seat doesn't have to be removed to top charge it.
Jan 28, 2009 | 1995 Honda VT 600 C Shadow
Health & Beauty Logo
286 people viewed this question
Top Health & Beauty Experts
ray gallant
Bill Boyd
Andrew Taylor
Andrew Taylor
Are you a Health and Beauty Expert? Answer questions, earn points and help others
