Was replaceing switch on my fast charge power booster yrs ago, and never finished and put in storage. I need wiring diagram for this unit. Thanks
SOURCE: need to charge 12v car battery
If battery is out of the vehicle, connect positive lead to positive terminal and negative lead to negative terminal.
If battery is in the vehicle, the proper way to connect leads depends on if it's a negative-grounded or a positive-grounded vehicle.
Here is a link to the manual for this charger.
Click where it says "Get This manual" (it's free).
Scroll down to pages 4 and 5 and it give detailed instructions on the proper way to connect leads and a lot more. It's a good manual to keep for future use.
I hope this helps.
http://powertool.manualsonline.com/manuals/mfg/schumacher/se520ma_se5212a_se1275a.html
SOURCE: need a 3 position switch for a Schumacher model se-2352 battery charger
Search for 3-position rocker switch
Use google and google image search.
Quick search shows 16 amp switches.
Probably the switches inside charger control contactor or relay.
Or connect directly to a circuit board.
The board might be bad, or relay points burned.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
