Question about Pride Mobility Products Pride Victory 10 - Three Wheel
Turn on. Won't go. Six beeps. What's wrong? - Pride Mobility Products Pride Victory 10 - Three Wheel
Posted by Richard Anderson on
Jeff Bird
  • Pride Mobili... Master
  • 1,346 Answers
Hi ring pride 1-800-800-8586 about youre problem It could b a fault with youre control box ......good luck
Posted on Nov 30, 2015
I have bought a used red head safe. It's open but I can't get it to close. Also, I don't have a combination for it and I'd like to make up my own. Can you help me?
Most likely it will not close because the lock has been activated while the door was open. Probably need to take it to a locksmith.
Jan 03, 2017 | Home Security
Scooter beeping
Six beeps would say it is the throttle pot not in its centre off position or the pot needs replacing. Is the wig wag lever loose by this I mean the lever is wobbly and moves up and down a fair bit. This would indicate its had its day. Have you had speed issues before this problem as this is normally the case before they go wrong altogether.
Sep 05, 2014 | Pride Mobility Products GoGo Ultra X...
How do i get back my video settings? put in wrong ones now won't work
turn the ps3 off....hold down the power button for 5 to 6 seconds til u hear a couple of beeps then turn it on....will reset your video settings to your avi cables.
Sep 11, 2012 | Sony Playstation 3 (PS3) Console
My Packard bell pc won't turn on an keeps making a
The number and timing of beeps will tell you what's wrong. You'll have to find the motherboard manual to find what the beeps mean though. Would be worth taking the RAM chips out, blowing any dust away and putting them back in.
Apr 20, 2012 | Computers & Internet
Directions on how to set favorite stations on a 2003 pontiac sunfire radio
AM / FM RADIO
Setting Preset Stations
The six numbered pushbuttons let you return to your
favorite stations. You can set up to 18 stations (six AM,
six FMI and six FM2) by performing the following
steps:
1. Turn the radio on.
2. Press AM FM to select AM, FMI or FM2.
3. Tune in the desired station.
4. Press and hold one of the six numbered pushbuttons until you hear a beep. Whenever you press that numbered pushbutton, the station you set will return.
5. Repeat the steps for each pushbutton.
RADIO WITH CD ( BASE LEVEL)
The six numbered pushbuttons let you return to your favorite stations. You can set up to 18 stations (six AM, six FMI and six FM2) by performing the following steps:
2. Press AM FM to select AM, FM1 or FM2
RADIO WITH CD (UP LEVEL)
The six numbered pushbuttons let you return to your favorite stations. You can set up to 30 stations (six AM, six FMI and six FM2, six XM1 and six XM2 (USA only, if equipped), by performing the following steps:
2. Press BAND to select AM, FMl, FM2, or XMI, or
4. Press EQ to select the equalization.
5. Press and hold one of the six numbered XM2. pushbuttons until you hear a beep. Whenever you press that numbered pushbutton, the station you set will return and the equalization that you selected will also be automatically selected for that pushbutton.
6. Repeat the steps for each pushbutton.
Additional details could find in your Owners Manual; hope this helps (remember to rate this answer)
Jul 02, 2011 | 2003 Pontiac Sunfire
Does a lamp error message (6 blinking red status lights) mean the lamp needs to be replaced? or could something else be wrong.
According to NEC technical support, if the status light flashes red six times, this could indicate a defective lamp. If a new lamp is installed and the project still won't turn on, the projector will need service.
Jun 15, 2011 | NEC NP400 Projector
My seat belt sensor keeps going off when I am wearing my seat belt!!
I found this post via genvibe.com, it worked for me on my 07 Vibe:
This will turn off the 1 minute beep if the car is running and either the passenger or the driver takes off their seat belt.
Get in the car and turn the key to on (don't start the car,) then change the odometer to display "odo" and not trip A or B.
Turn the key off.
Turn the key back to on. Within six seconds of doing this, press and hold the odometer button. Do so for 10 seconds. Then, while still holding the button, buckle up, edit: then unbuckle. The "odo" display should then change to say "b-on." let go of the odo button to get it to read "b-off." Then wait for the display to change back to the odometer. That's it, you're done.
The car will still beep right when you turn it on for 3 seconds if you don't have a seatbelt, but the dash light will continue flashing till buckled up. It won't beep if you or your passenger unbuckles for a moment. Salvation!
Read more: http://wiki.answers.com/Q/How_do_you_disable_a_driver's_seat_belt_alarm_on_a_pontiac_vibe#ixzz1MxTn2Oa0
May 21, 2011 | Pontiac Grand Prix Cars & Trucks
I have mb-msi2000-815e pro ver1, it is constantly beeping. change the memories,agp,, but it still continues.what could be wrong/
1.Your first step is to look at the information about the meaning of the beeping codes. Beep codes are important and useful tools when troubleshooting booting issues. When you turn on your computer system, it is called POST (Power On Self Test).
2.No beep is usually a power problem that can be related to the power supply, motherboard or both. Always check your battery power before thinking there is a bigger problem.
3.One beep is a normal POST. That means everything is fine.
Two, Three, or Four short beeps are normally about the memory of the machine. If there is a problem with one of your memory chips you should get beeps of different combinations in this area. If you get two or three short beeps, one or both of your memory chips could be in trouble.
4.Five beeps point toward motherboard or CPU problems. Make sure your memory and video card are seated properly. Try removing them and putting them back in, only if you are comfortable with computers.
Six, seven and eight beeps.
Eight beeps indicate problems with your video card. Six or Seven are CPU, or a bad chip on the motherboard.
Nine beeps mean the BIOS is bad. Replace the motherboard.
Ten beeps means the problem is in the CMOS. All chips need to be replaced.
5.Eleven beeps are related in the cache of the mother board and this means that the motherboard needs replaced.
One long and three short beeps mean that it is related to a loose memory chip. Try reseating it.
One long and eight short beeps means that the video cards needs reseated.
6.I hope that this list of beep codes will help settle the panic you feel when your computer is sick. If all fails, Then you inform me
Feb 21, 2011 | ASUS Intel 815E Chipset CUSL2-M...
Six beeps at post and no joy with boot up
The exact meaning of the beeps for Dell depends on their... rhythm.
http://www.nullamatix.com/dell-diagnostic-beep-code-troublshooting-chart/
Six beeps might indicate a simple CMOS failure caused by a bad battery, which is easy to replace.
Nov 08, 2009 | Dell OptiPlex GX280 PC Desktop
Six beeps of the standby light...
Yes your suggestion is correct. This type of problem occurs due to humidity also. Solution is if your a technical person or service person just remove main pcb from the tv and blow all dust and clean it. Check whether the dry soldered in power supply area and jungle ic area. if found clear it. Now the tv is working well and good. 6 times blinking means problem in jungle ic area.
Aug 23, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Pride Mobility Products Pride Victory 10 - Three Wheel Logo
104 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Bird
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
