Televison & Video Logo
Carl dobson Posted on Nov 29, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hisense UB55EC591UWTSEU tv can you please find me sky remote code
Electro Med Services
Level 3:
  • Hisense Master 6,694 Answers
  • Posted on Nov 29, 2015
Hisense Master
Level 3:
Answers
6694
Questions
Helped
1870103
Points
21433
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
5 Related Answers
Anonymous
  • 372 Answers
  • Posted on Jan 20, 2008
SOURCE: Tv wont switch to Sky when remote control is pressed
Hi.
On the sky box do the following.
Check scart to tv is in the correct socket marked TV.
Try pressing services
then system setup
then picture settings.
Then try switching scart control to on or off.
If this sorts it great. If it doesnt check scart lead has all pins wired & not only A few.
http://dysonmanuals.llc.nu
Chris..
Anonymous
  • Posted on Aug 04, 2008
SOURCE: Sky remote code for LG 42LC46 tv
After spending hours on this I found that code 0206 worked on my sky+ remote(with LG 42LC46). On an old sky remote, prior to version 4 (inside the battery compartment), just use 206.
This code was actually for a LG 42PX5D but it works perfectly on my tv.
Anonymous
  • Posted on Aug 12, 2008
SOURCE: gu15wdvdt tv .sky remote code
posted by mike 13 aug 2008
I have just had sky installed and the code for grundig gu15wdvdt is 1239
Anonymous
  • 6487 Answers
  • Posted on Oct 23, 2008
SOURCE: hisense tv
Try this code 142, inform us for any updates.....
Anonymous
  • 27 Answers
  • Posted on Apr 04, 2009
SOURCE: Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
1helpful
What is th? code for a sky remote to work a hisense smart tv
Hi Hans, Unfortunately that remote control will NOT work on a hisense television... The link below is a sky remote control codes site, Scroll down the list and HISENSE isn't on the 3 or 4 digit list. Sorry mate......
Sky Remote Codes
2helpful
11answers
Hisense tv
so whats the remote you have there?
Can anyone give me sky remote code for my me hisense 55 inch 4K tv as I cannot turn volume up or down with my sky remote
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
I have a hisense LHD4229EU tv.what code do i need for my sky+ remote to work on this tv.
If your remote is version 9 or 10 the code is 2065. If the version is lower than 9 you'll need to upgrade to the latest version.
Sky com Find your remote control code
3helpful
2answers
Cant get sky remote to work on easy-touch tv
I work for Sky. Ive been trying to find the code for you. There are several ways you can do this.
If i could get a picture of what the volume bar on the television looks like, this is one indication to what manufactor made the television.
The other way you can do yourself. Note this will does take some time.
TV
red + select
TV
POWER
repeat the TV , POWER until it turns you tv off. Then press SELECT to save.
The steps I mentioned above. what this is doing is going through all the remote codes on the remote itself. Hense you not inputting any numbers.
As I mentioned it can take 15 - 20 minutes depending on luck. if you get the code early on or not.
Hope this works for you.
Little dish fitter
How to tune sky remote without code
Hi There, I have a Hisense 81 cm Plasma PDP 3208 TPW 3208
I need code for my urc-7544 so I can use the remont on this TV
Thank you
Nelson
Cape Town
S A
2helpful
2answers
My sky remote wont control the volume on my tv
Hi Re Easytouch 42" HD TV - look for Hisense - I took a guess and LCD3204 EU code 376 - remote works but buttons don't tally up - getting there slowly!
Just bought a madeforyou 4:1 remote that is programmed on my PC.
Ok - not proper solution yet but nearly there!
Top Hisense Televison & Video Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
