Question about AccessData Password Recovery Tool Kit (ftk 1.4x)
YALE PREMIUM HD720 CCTV DVR
I CHANGED PASSWORD AND HAVE FORGOTTEN AND CANT ACCESS CCTV SYSTEM. YALE DVR H4B-HD
Posted by Sajidha Iqbal on
Joe M
    New Friend:
  • 93 Answers
Contact the manufacturer to see if there is a way to reset the account.
Posted on May 05, 2016
Hi there a friend of ours installed our dvr modelH264 he has forgotten the paasword any help in resetting this would be great
CCTV & Networking Technical Support
1. Connect Your DVR to Network.
2. Press Window Key + R in Your PC and Type "ping -t (DVRIPADDRESS)" if it is giving reply then you are ready to process next step.
3. You need to access your dvr with telnet port (23)
for that download tool "Putty" Link: https://www.chiark.greenend.org.uk/~sgtatham/putty/latest.html
4. Open Putty Tool and input dvr ip and port 23 (telnet)
click connect login username: admin password: xc3511
if success then email me on [email protected]
I will help you to reset your DVR.
Visit:- CCTV Networking Technical Support
Nov 28, 2017 | The Home Security
My CCTV is showing hacked on the cameras. How do I reset my password
Your CCTV is connected via an Internet connection.
I'll recommend to isolate the network devices from the Internet before continuing.
This is covering only basic steps, I recommend to get the instruction manual for the CCTV and read it.
  1. Enter the administration section of the CCTV recorder/DCR/NVR by entering your admin account name and password.
  2. Go to the admin setup of the CCTV. Search for overlay and verify if the hacker inserted text on the overlay feature, if you don't use overlay, disable it.
  3. Then check each camera name tags in the admin section. Change the text if it was hacked.
  4. Change the password for the CCTV DVR/NVR/Camera, I bet it was never changed. Write the password down and store it in a safe place.
  5. Last option: If you can't find the place do a factory reset of the DVR/NVR/Camera. (Do make a backup before a factory reset to an external device if possible).
  6. Once the factory reset is done, you will have to reconfigure the recording options for each camera.
  7. Last point after the factory reset, change the admin password.
Are there other devices sharing the Internet connection with the CCTV?
If this answer is YES, then check them for hacker breach.
  1. I'll recommend to increase the security on the Internet Router.
  2. Any device sharing the Internet with the CCTV should be checked for breaches and made secure.
  3. Speak to your ISP and ask for assistance if you have a fixed IP address to your CCTV system. Ask them for advice. Layer 7 routers are more expensive but more secure.
  4. Load all updates for any devices!
Get an IT security expert to assist you with the breach if necessary.
Sep 29, 2017 | The Home Security
How do i reset my dvr
If you stuck in CCTV DVR Password Reset process. just visit
CCTV & Networking Technical Support Channel on youtube.
Here is the link:-
Jan 13, 2016 | Swann Communications Home Security
How do i re set my qvis cctv system
Open the case. There is a button cell inside. Remove that for about 12 hours with the CCTV disconnected from the mains. The password should be reset.
Feb 20, 2015 | Sharp Qvis Apollo Hd 16 Channel Security...
I reset my dvr ltd 7908 and cant get the password again
try "admin".
is the default password for everything.
Feb 13, 2015 | Home Security
Fusion password reset
I didn't read the entire manual, but you may want to take a look at a Fusion DVR Manual to see if there are instructions for resetting the system password.
Jan 19, 2013 | Honeywell Home Security
I have forgotten the admin password of dvr (H.264) the motherboard serial is BS160 V1.01 20101009. how could i recover my system or change the password
Remove the top cover, remove the lithium battery, turn it on and check if the time is Mon 01-01-2001 00:00:00 Then enter this password: ecdGqv (respecting uppercase and lowercase). Message will appear with super login password, and the DVR will restart and return patterns of manufactures.
Jun 19, 2011 | FPS 4 Channel Standalone DVR system,...
I changed the admin password on my sentient cctv dvr from the default 123456. I saved the changes but now get the message incorrect password when I input the six digit password I stored. Please help
Hello
After system boot-up, hold a right mouse click
button and there will be login window. Hold a left
mouse button to click the order of "Account", and
input correct account. Then left click the order of
"Password" and input correct password. At last
left click "Login" to enter system. There is one
factory-preset login "account/password"
"admin/111111" at admin level. The user can
use it to login the system for the first time
May 22, 2011 | Ganz DR4NC-160 DVR DIGITAL VIDEO RECORDER...
Cctv remote view/ adtran total access 900e
It's not likely that VZ gave you dynamic IP's, but it's possible. You should have been given more than one. If not, it's better to get more and a set of configuration instructions. In the last one I set up, we put a 5-port switch on the ethernet port coming off the Adtran, then fed 2 routers and a security system from the switch. Our gateway was one number lower than the bank of IP's we had, and we just gave each piece of equipment a static ip address and gateway to the gateway :-)
Carl
Sep 19, 2008 | Computers & Internet
Computers & Internet Logo
807 people viewed this question
Top AccessData Computers & Internet Experts
Ivan Gavric
ray gallant
Joel Rodriguez
Joel Rodriguez
Are you an AccessData Computer and Internet Expert? Answer questions, earn points and help others
