Remove all packaging materials, sticker, and labels.
Clean the basket and pan with hot water, soap and a non-abrasive sponge. These parts are dishwasher safe.
Wipe the inside and outside of the appliance with a clean cloth.
Place the air fryer on a flat and even surface.
Put the basket in the pan.
Plug unit in to an approved wall socket.
Place the ingredients in the basket and then put the basket and pan back into the appliance. The fryer LED will light up.
Set your cooking time and temperature by either choosing one of the 8 presets or manually set it with the "+" or "-" buttons. See "Cooking Guide" to determine the right time and temperature.
Once you have set your cooking time and temperature, press the "Start" Button.
The heating icon and fan icon will be blinking and this means that the fryer is starting and is circulating the hot air in the fryer. NOTE: During hot air frying, you will notice that the heating up icon will blink and stays from time to time. When the heating icon is on, it means that the temperature inside the fryer has reached the set temperature. When the heating icon is blinking, it means that the temperature inside the fryer dropped and is below the set temperature and is currently heating up to the reach the set temperature.
Some ingredients may need to be shaken halfway through the cooking cycle (see "Cooking Guide"), To do this, pull the pan out of the air fryer by the handle, the air fryer will automatically shut down. Then shake the contents in the basket, then slide the pan back into the air fryer and it will resume the cooking cycle. CAUTION: Do not press the button on the handle during shaking; this will detach the basket from the pan.
When the cooking time has been reacher, the air blower will stop in 20 seconds.
Pull the pan out of the fryer and place it on a pot holder. The cooking pan is VERY HOT do not put on surface that can burn. NOTE: Oil from the ingredients will gather in the bottom of the pan, so be careful when pulling the pan out of the fryer.
To remove the ingredients, press the button on the handle of the pan to detach the basket. DO NOT TURN THE PAN OVER. PLACE ON A POT HOLDER.
Upon placing the cooking basket back into the air fryer, the air fryer will automatically go to the previous cooking cycle and will repeat the previous cooking cycle, press the cancel button to stop and reset the air fryer if desired.
Turkey Fryer is deep enough to fry a 12 to 14 pound turkey and wide enough to be used as a seafood boiler. Heating element is made of stainless steel. It comes with aluminum bailing basket with adjustable quick drain system, control with safety shut-off and a built in digital control with thermostat and timer. Swing out drain valve for easy draining and clean up. CSA certified.
Deep enough to fry a 12 to 14 pound turkey and wide enough to use as a seafood boiler, the Cajun Injector's Electric Turkey Fryer provides home fried cooking without the mess and hassle of stove top or outdoor methods. Equipped with a 30Qt. aluminum bailing-basket, you can submerge and fry a whole turkey or any other foods you'd like to cook fully covered. When the food is finished cooking, simply lift the basket up with the hanger hook, and allow it to drain over the pan with the adjustable quick drain system. A swing-out drain valve to empties the used oil when its time for clean up and a built-in digital control with a thermostat and timer ensures that the food cooks exactly as you intended. The CSA certified fryer features a clear lid so that you can check on the food without risk of burning and is equipped with a stainless steel heating element for long lasting quality.
To insure long life and satisfactory performance from your Nordic Ware Rice Cooker, follow these simple guidelines (microwave use only).
1. Before using your Rice Cooker wash it thoroughly by hand in warm soapy water or in the dishwasher (top rack only).
2.Foods with strong colors (particularly red sauces, tomatoes) may stain your cookware.Staining that may occur will not affect the use of the cookware.
(Cooking times may vary due to variations in microwave ovens.Adjust cooking times for best results in your oven.)
To Cook Rice:
1. Remove basket.
2. Pour 1 cup of uncooked rice into the bottom of the basket, rinse rice thoroughly with cold water.
3. Transfer the rinsed rice from the basket to the bottom of the cooker.
4. Add 1 1/2 cups of water and 1 tsp salt (salt is optional).
5. Secure lid and lock clamps. Open vent holes.
6. Microwave on medium setting (50%) for 10 - 12 minutes (white rice) or 18-20 (brown rice).
7. Remove from microwave, close vent holes and let stand with the lid fastened for 4-5 minutes (the steam continues to cook the rice.)
8. Remove rice from the cooker and fluff with a fork.
Yields: 3 cups of cooked rice or 4 to 6 servings.
Cooking Potatoes and Vegetables:
1. Insert Basket.
2.Pour one cup of water plus 1/4 tsp. salt into the bottom of the cooker.
3. Peel vegetables (if desired), cut into evenly sized pieces and place inside basket.
4. Secure lid and lock clamps. Close vent holes.
5. Microwave on high for 3-4 minutes.
6. Remove from microwave and let stand with lid fastened for 3-4 minutes (the steam continues to cook the vegetables.)
Cooking Pasta:
1. Remove basket and lid (lid not used initially for preparing pasta inside the microwave).
2. Pour 2 cups (5 oz.) of uncooked noodles into the bottom of the cooker.
3. Add 2 1/2 cups water.
4. Microwave on high setting 10 minutes, stirring after 5 minutes.
5. Remove from microwave, stir noodles, secure lid and lock clamps. Close vent holes. Let stand for 3-4 minutes.
HELPFUL HINTS TO ENHANCE THE FLAVOR OF ANY MICROWAVE DISH:
1. Use chicken broth instead of water for added flavor.
2. Add a little butter or oil to contents.
I bought one at a thrift store for $8.00 and it had the same problem. All I did was put some cooking vegetable oil on the open basket door where it stuck, using a q-tip. It has worked great for over a year now.
Place the oil tub in the housing, and put the control unit on the back of the housing with the heating element inside the oil tub. Put room temperature (not chilled) shortening and/or lard in the oil tub. (Solid fats make better french fries, IMO.) Put the unit where you aim to cook, on a clear expanse of counter, where no one will knock it off. You are about to make boiling oil, and the potential for injury is truly medieval. Attach the magnetic power cord to the back of the control unit, and position the unit with the front of the control unit, which is at the back of the oil tub, facing you. Plug it into the wall. The magnetic cord attachment is easily knocked off, which is a safety feature, so don't knock it. If it comes off, just put it back on and restart the unit. Push button at lower right of control unit that looks like a 0 and 1 superimposed on each other. This is the power button. Put the lid on the unit with the two slots on top of the lid facing towards the front of the unit where you are. These two slots are where the basket will sit, but you haven't used the basket yet. Adjust the temperture using the + and- buttons. 375 is good for french fries. Now wait until the red light goes out and the green light (I believe) stays on. Now it's up to temperature and you can cook. Put frozen or washed and patted-dry (with a towel) french fried potatoes or battered fish or whatever you want to cook in the wire basket. Quickly lower the basket into the oil and replace the lid: back edge goes down first, then front of lid last. Set the unit's timer if desired, or just use your own timer. It will beep at you when your time is up. When you're done, you can wash the basket by hand or in the dish washer and wipe the unit off with a warm soapy dish cloth. Wait until the oil is cool to room temp before attempting to put the unit in a cupboard. Very hazardous with large potential for mess otherwise!
Here are the instructions that came with the cooker:
Cooking times may vary due to variations in microwave ovens.Adjust cooking times for best results in your oven. To Cook Rice: 1. Remove basket. 2. Pour 1 cup of uncooked rice into the bottom of the basket, rinse rice thoroughly with cold water. 3. Transfer the rinsed rice from the basket to the bottom of the cooker. 4. Add 1 1/2 cups of water and 1 tsp salt (salt is optional). 5. Secure lid and lock clamps. Open vent holes. 6. Microwave on medium setting (50%) for 10 - 12 minutes (white rice) or 18-20 (brown rice). 7. Remove from microwave, close vent holes and let stand with the lid fastened for 4-5 minutes (the steam continues to cook the rice.) 8. Remove rice from the cooker and fluff with a fork. Yields: 3 cups of cooked rice or 4 to 6 servings. Cooking Potatoes and Vegetables: 1. Insert Basket. 2.Pour one cup of water plus 1/4 tsp. salt into the bottom of the cooker. 3. Peel vegetables (if desired), cut into evenly sized pieces and place inside basket. 4. Secure lid and lock clamps. Close vent holes. 5. Microwave on high for 3-4 minutes. 6. Remove from microwave and let stand with lid fastened for 3-4 minutes (the steam continues to cook the vegetables.) Cooking Pasta: 1. Remove basket and lid (lid not used initially for preparing pasta inside the microwave). 2. Pour 2 cups (5 oz.) of uncooked noodles into the bottom of the cooker. 3. Add 2 1/2 cups water. 4. Microwave on high setting 10 minutes, stirring after 5 minutes. 5. Remove from microwave, stir noodles, secure lid and lock clamps. Close vent holes. Let stand for 3-4 minutes.
