Question about Kodak ESP Office Equipment & Supplies
What is error code 3806?
CHANGED INK CART. AND GOT ERROR CODE 3806
Posted by MARK A EVANS on
Kaye Day
  • 744 Answers
Error Printer error 3806 3807 3808 3809 3810 or 3811
Kodak does not say what the error is but they do show how to deal with it.
Posted on Nov 29, 2015
I have a Canon inkjet printer. What does error code B201 mean?
ink cartridge is not compatible with this machine
when you buy an off brand ink cart sometimes they will not work. and then again I have had this probem too. the softwaare was updated and then all of a sudden my ink cart did not work anymore. for some reason all the printer up dates are set to reject off brand ink carts i guess they are not selling enough of there brank of ink so they set it up not to take off brand ink carts. if you can fiind the up date and uninstall it and that might solve your broblem. if not you will have to buy a name brand ink cart
Sep 13, 2018 | Canon Office Equipment & Supplies
Receiving cartridge error consilt user guide, can you help mke?
Well, without knowing what printer it is or the full text of the error message, or what lead up to your proboem, this is a guess.
Wrong ink cart.
Empty ink cart
Missing ink cart.
Mis-installed ink cart.
Many ink carts have a piece of tape over the contacts or over an air breather hole. This must be removed before installing it.
Some printers have delicate contacts that can be bent or broken if the cart isn't installed carefully.
Jun 29, 2015 | Office Equipment & Supplies
My kodak esp 6100 keeps on showing error code 3806?
Disconnect power cord, let it set 30 sec, reinstall cord. If problem still there pull out the printheads and reinstall, may have to do this a few times, if problem still there may need printheads.
May 07, 2014 | Kodak Office Equipment & Supplies
Displaying error E and 5 (In Blinking) and error code 2,114 while scanning........help me out of this...........thanx
The e2 error os no paper, e5 is improperly or damaged ink carts, as is the e14 error code. Make sure that there is plently of fresh paper, and replace the carts with new canon carts. If you are using refilled carts in this machine, the failure rate of this series of carts is nearly 60%. Last step to try would be to unplug the printer from power and let sit for at least 10 minutes, plug back in and power up.
Sep 29, 2010 | Canon PIXMA MP150 All-In-One InkJet...
ERROR CODE 3805
You really need to call kodak support for this one
because the edge sensor of the printer is not
working thats the meaning of
3805 they will replace the printer
Mar 30, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Error code # 1203
Error 1203 is basically a cartridge error. Try cleaning the contacts on the cart & in the cart carrier, reseat the carts & then power off the printer. while holdin down the stop clear button, rebrick the power chord.
Jun 30, 2008 | Lexmark X4270 All-In-One InkJet Printer
No cartridge
Could you please give some more details:
Do you use gerneric ink instead of the original ones?
When did you get the error code? During normal condition or after a cart change?
This info will quite increase the range of solving suggestions!
Dec 23, 2007 | Brother Multi-Function Center MFC-3360c...
Open Questions:
282 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
