Question about Canon FAXPHONE L80 Laser
Fax does not know paper is loaded. says load paper
When i put paper in the tray, the fax still says load paper
Posted by raybi on
  • Anonymous Nov 20, 2007
    Same problem. Tried loading paper, then opening and closing cover. Doesn't seem to work. Any other suggestions?
  • Anonymous Nov 30, 2007
    I tried opening & closing the machine but it still indicates I need to load paper.
Anonymous
When you load your paper, you must press the Stop/Reset button for it to reconize you have loaded paper.
Posted on Dec 14, 2007
Anonymous
  • 115 Answers
The Paper tray has a sensor for the same. Open and service the sensor and that will solve ur problem. put the lever of paper loading tray of and on and then try it.
Servicing will solve the problem or tell again if u won't solve.
Viren
Posted on Nov 27, 2007
Nasir
    New Friend:
Will try all and see what happens
Posted on May 06, 2013
Anonymous
I just unplugged and shut down the machine, put fresh paper in, waited a minute and it started working again.
Posted on Nov 30, 2007
  • Joseph Maruca
    Joseph Maruca May 14, 2018
    Warning about that: Unplugging the machine fixes the error but it also clears any queued jobs. I had three jobs that queued because of this 'load paper' error. When I unplugged and plugged in the machine again, it automatically printed a Memory Clear Report that showed those jobs were deleted. Fortunately I recognized the numbers of the senders and was able to contact them and get those faxes resent to us.
1 Related Answer
redzventures
Jay Otaigbe
  • 149 Answers
SOURCE: Sir, can anyone help me with my fax (canon fax
You either have a paper path blockage or your feed rollers are worn. You'll need to take it apart to check though. Try removing paper, turning machine off and on and re-inserting paper. Remember to fan (separate) paper before loading, it could be static causing the sheets to stick together and jam in the machine.
Posted on Jul 06, 2009
IN WHAT DIRECTION DO TO PUT THE PAPER IN TO FAX
directly above the control panel you will see the tray where to put in the document you want to fax, load the document top edge first face down, lcd should change to enter fax no & press start.
Please rate if this helps
Thanks, vikroks
Mar 25, 2011 | Brother IntelliFAX 1270E Plain Paper Fax
Fax output error
Pretty sure your paper tray button is set to get paper from the bottom paper cassette which is the tray that slides into the bottom of the printer.
If you switch the paper tray selection button* to use the rear feed tray you'll probably find it will print faxes sucessfully or you can put paper in the cassette tray...
*The paper tray selection button is just under (and slightly right of) the "Memory Card" button and has an icon image of the printer with two LED's (top and bottom). These lights indicate which of the trays is currently selected...
Hope that helps.
Mar 27, 2010 | Canon PIXMA MP830 All-In-One InkJet...
How and were do you load the paper in the machine
there should be two flaps; the first one is the larger flap at the back,put the blank paper to print there. where the smaller flap is (the doucments go) in the front, When you get ready to fax the doucment. It all should come out into the tray at the bottom of the fax machine. Look under the front of the fax machine and you should see a round indentation, put your finger into that and pull the tray out..
Mar 02, 2010 | Lexmark F4270 Plain Paper Inkjet Fax
How do you access bypass tray?
The bypass tray is refered to as the multi-purpose (MP) tray. It is located vertically on top at the back of the fax machine. The fax needs to be programmed (told what size of paper is loaded) by opening the One-Touch Speed Dialing panel, press the 'Data Registration' button, press 'Set' button, then using up or down arrows to select " 5.PRINTER SETTINGS ". Press 'Set' button, then press down arrow to display " 2.PAPER SIZE ". Press 'Set', use arrow s to select CASSETTE or MP TRAY. Use arrows to select appropriate size of paper loaded. Press 'Set'. Press 'Stop' button to return to standby mode. Reference pages 15-11 and 15-12 in LC 2050 Users Guide.
Dec 17, 2009 | Canon LaserClass 2050 Plain Paper Fax
Error message saying "supply rec. paper"
There is a small side tray on the right side of the machine,check if there are paper loaded in.
Jun 30, 2009 | Canon LaserClass 9000L Plain Paper Fax
Sir, can anyone help me with my fax (canon fax l295)for a problem, it was always indicating that "load paper" even though i put paper on the tray once it was start feeding it makes an paper jam error and...
Jun 11, 2009 | Canon L295 Plain Paper Laser Fax
Having trouble sending a fax and receiving one,, also where does
To send a FAX load the pages in the auto feed tray on the top of the unit. To receive a FAX, load the paper in the paper feeder vertically on the back of the unit. Suggest you consult your users manual.
Jan 19, 2009 | Epson Stylus CX9400 Photo Printer
My canon faxphone l80 can not be loaded paper, once I load paper in the tray, the monitor still shown load paper
Please shut down the unit and remove all paper. Wait ten seconds turn the fax backon without paper. mAKE SURE THE FAX IS ONLINE. hAVE SOMEONE SEND YOU A FAX SO THE MACHINE DEMANDS THE PAPER. SEE IF THIS WORKS
Jan 19, 2009 | Canon FAXPHONE L80 Laser
PAPER TRAY NOT RELEASING
After puting paper in the tray you should press the start button. GOOD LUCK.
Nov 20, 2008 | Samsung SF-560 Plain Paper Laser Fax
Loading paper
is the tray going up when you put the paper in and close it? is the sensor there? there has to be a lever that is free floating in the tray, when you put paper it goes up and shows has paper, when out it goes down for add paper.
Jan 14, 2008 | Canon FAX-L1000 Plain Paper Laser
Canon FAXPHONE L80 Laser Logo
1,046 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
