Televison & Video Logo
Christel Ehrbar Posted on Nov 28, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ineed a manual to set tv, add cable box and vcr
Claude Kayser
Level 3:
Top Expert:
  • Master 9,098 Answers
  • Posted on Nov 28, 2015
Claude Kayser
Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5067181
Points
28436
Images for manual to set tv
PDF]Apple TV Setup Guide (Manual)
https://manuals.info.apple.com/MANUALS/.../AppleTV_Setup...
Apple Inc.Contents. 1. Connect. 2. Configure. 7 What's in the Box. 8 What You Need. 10 Apple TVat a Glance. 12 Setting Up Apple TV. 18 Network Configuration.
[PDF]USER MANUAL - VIZIO
Restore sound on my Tv, suddenly lost.
  1. Check if the mute button on the cable box/TV/VCR is activated. If so, turn off the mute feature
  2. Verify the volume on the cable box/TV/VCR is not turned all the way down, either by adjusting the volume level on the equipment itself or with the remote control
  3. Check if the TV has an earphone or headphone jack. If so, make sure there are no earphones or headphones plugged into it
  4. Check if the Cable Box/TV/VCR has a SAP/MTS switch (Secondary Audio Program / Multichannel Television Sound). If so, make sure it is set to the proper setting. Consult your TV/VCR manufacturer's user manual for information for your specific TV/VCR. Click here for information on changing this setting on a Cable Box
  5. Check behind ALL TV and equipment (Cable box, TV, VCR, DVD, stereo receivers, etc) and the coax cable at the wall outlet for any loose or damaged connectors
  6. Make sure all equipment and connections are hooked up correctly for the video and audio based on the type of connections being utilized
Vcr tape doesn't show on screen when playing
If the picture from the DVD shows on the screen, but the pictire from the VCR does not, it is most likely because you are using sockets on the back of the player that are exclusively for the output from the DVD.
Please review your connections in relation to the diagram below. If the cables from the player to the TV are only in the red box, you will not get any picture from the VCR. You will need to move the connections to the sockets in the green box or add a separate connection for the VCR using the sockets in the green box. Whether or not this is possible depends on what input sockets are available on your TV.
You will notice the heading above the red box says "DVD". This means the connections in this section can only be used for DVD. The heading above the green box says "DVD/VCR" meaning the connections here can be used for both.
There are a fews ways to set this up. To get the best picture quality from DVD, you should continue using any connections you may have in the red box and add another cable from the green box to the TV for the VCR. You will also need to select different INPUTS on the TV depending on whether you want to watch DVD or VCR if you are using 2 cables.
I suspect this will be the cause of your problem. If you need any further explanation or assistance, please reply to me by clicking on "Add a Comment" below your question. If you would like me to draw a connection diagram between the DVD/VCR and your TV, please let me know the brand and model number of your TV.
Hope this helps.
Regards,
BElectric
How can I receive and record cable channels on my Sony SLV 750 vcr? The tuner only displays channels 1-99 on the vcr. Thank you.
I will be assuming you have analog cable TV service, no cable box. If you have a cable box, the instructions would be different.
There are many steps to properly setup your Sony VCR and they should ALL be setup to correctly record channels, however just to cover your question here....
Press MENU on the remote control for the VCR and you should see on your TV screen, the main menu options. Select TUNER PRESET. Press OK. Set Antenna/Cable to CABLE. Next Select AUTO-PRESET. Available channels will be scanned. This may take a few mins. so be patient. Channels could go up to 125. This should make available cable channels ready to record/view.
You can ADD or Delete a specific channel also if one is missed or undesired by selecting MANUAL SET.
I have lost the manual and would like to hook up the VCR to my TV in order to record programs. Can you help? JVC Video Cassette Recorder HR-D18OU Thank you.
Is the incoming signal OTA or cable? (If cable, is it analog (CATV) or digital (QAM)?)
Most TV's do not have a video out but you should check your TV. Assuming the usual TV with no video out, then you will need a set top box to record any program other than analog signals (CATV or a low power OTA option). The VCR only has an NTSC (analog) tuner.
For an OTA signal, take the coax from the antenna to a digital-to-analog converter coax in, then coax out of the converter to the coax in (tuner) of the VCR. Then set the VCR to channel 3 or 4. Set the switch on the converter. (Some VCRs will record Line In or Input, so you could use the composite out of the converter to the VCR.) Then coax out from the VCR to the coax in on the TV and set the TV to Channel 3 or 4 as well. Set the switch on the VCR. (Alternatively use the composite (A/V) out on the VCR to the composite In on the TV and set the input to AV1 (or whatever the TV calls the input). Digital cable will be set up like the OTA, except for using a cable set top box instead. You may want a splitter to allow for watching one program while recording another. In that case, put the splitter before the set top box if the TV has the digital tuner. Otherwise put it after the set top box. In both cases, you will need to use the AV (composite out) on the VCR to the TV.
For analog cable, take the coax cable and connect it to the VCR's coax in. Then connect the coax out or AV out to TV.
Set the VCR to the desired station and press REC. For timed record, enter the menu and set the time to start and end the recording as well as the channel. If you are using a set top box, set that to the desired station and then press record. (Leave the VCR set to Line in or channel 3 (4) as needed.)
Manuals for some JVC vcrs are here: http://support.jvc.com/consumer/product.jsp?categoryId=CATG0002&productId=PRD4600001&archive=true . A manual for a similar model will help since they all connect the same way. However the HR-D18OU is not in the list.
I hope this helps.
2answers
I got a magnavox dvd recorder and 4 head hi-fi stereo vcr and im having trouble with hooking it up to my cable box how do i record shows on my recorder without switching inputs on my tv because i switch...
Don't hook the DVD/VCR recorder through ur cable box.Hook the DVD/VCR recorder through ur tv only it should work find.This way each units have it own direct functions to the tv.U recording the shows from the tv not the cable box ok.
Problem recording of hd tv with cable box from
Here are a few items to check and how you need to set your recording.
1. Your HD box should have a coax out (or to TV) connection on the back of the box.
2. Connect a coax cable from the back of the HD box to the "RF IN (FROM ANT.)" in the back of the VCR.
3. When you set your VCR to record you need to set it to copy channel 3 and tune the HD box to the channel you want to record.
This should fix your problem...
Good Luck...
Ineed to know how to interconnect our tv, vcr, dvd and top set box, Can you help? Philips DVP3120/05, Philips VR720 Philips 282 tv with built in dvd and Bush free view top box.
Problem solved : incorrect connection of scat leads Solved by roof top digal aerial Digi top box and on to VCR. and then on to TV.
Scart from VCR to TV
Scart from VCR to DVD
Scart from Digi Top Box to TV.
Everything now functions correctly
Equipment connected:
Philips VCR: 720/07
Philips TV : 28PW6515/05
Philips DVD: DVP3120
Bush top box
How to set up VCR with cable, have wide screen TV, cable box and VCR, only cable is hooked to TV at moment, want to add the VCR
googled how to solve problem, carried out instructions provided, worked like a charm, thank you!!!
Connections
Without the manual !!
1)VCR INPUT:: [Cable_antenna In] the coxial screws on from "output" of cable box or ( airwave )antenna.
2) VCR output:: connect another coxial into input of TV. You should be able to keep all the other wires connected from SONY theater system.
note:: your VCR has a switch for VCR\TV. When u have a VHS tape playing a movie & switch from VCR to TV, you will see the channel that is on the VCR not the cable box\ antenna input.
example:Cable channel is on Ch.122, & your TV must be set to Ch.3 to view cable.If your VCR is set to Ch/5 you may not see that Ch.122.You will still be able to see your VHS tape when u place the VCR\TV switch back to VCR.
I am going to share wt.u a $100,000,000.00 trick:put any ch.on cable box.Switch VCR\TV to TV,change channel ON VHS tuner.When u come to the [picture] that the cable box is on,Then that is the Ch.u can see cable ON the VHS.
U owe me!!
Recording instructions
First, whether or not you can do this will depend on cable box useage, and how the VCR is hooked up. In the earlier days of cable TV, & off-air reception, this was a simple task. If you have a satellite receiver box or cable box which is used to tune the channel, rather than using the TV itself or the VCR tuner, then recording one channel while watching another may not be possible. While I don't know the capabilities of newer sat/cable boxes, older ones sent just one signal out to the external equipment (TV etc.) That one signal (channel) is all that is available. If you received a manual with the sat/cable box, see if it says anything about this issue. That being said- if you don't use a sat/cable box, but instead use your TV or VCR to select the channel you are watching, then assuming the VCR is hooked up inline with the TV, just setting the VCR/TV option to TV will pass all channels through to the TV, and you can then use the TV to select whatever channel wished, while the VCR is recording something else. Hopefully I haven't confused you. If another contributor has some additional info on the capabilities of sat/cable boxes of today, please read their contribution.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
