Tablets & eReaders Logo
S
Sandra Schulkins Posted on Nov 28, 2015
I want to delete some of whats on my book - Tablets & eReaders
Lisa Smith
Level 1:
New Friend:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Nov 28, 2015
Lisa Smith
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
11
Questions
0
Helped
2699
Points
30
Are you saying you're writing a book? If you are writing a book, and want to delete a part of it, make sure you haven't published it yet. If you have, you will need to delete the book off the e Store, and rewrite the book. If you haven't published it yet, you're in luck. Go into the program you're using to write the book, select the area you want to delete, then press the 'delete' or 'backspace' button. Hope I helped!
~Conner
3answers
How to delete books from kindle permanently?
Hello friend...
Here, I am recommending you the best possible method to delete books from kindle permanently, Just Follow these steps:
1. Turn your Kindle on. Once you're on your Home Screen navigate through your library until you find the book you no longer want.
2. When you select the book it will give you a list of options -select "Remove from Device." The book will go into your Archive. Files in your Archive are not fully stored on your device, but are there to maintain the record of your purchase.
3. If you want to remove the book permanently you can do that as well. Sign into the Amazon account you have linked with your Kindle and go to "Manage Your Content and Devices." You should be looking at a list of your purchases. Find the book you want to delete and click the button on the left side of the title.
4. From the drop down menu, select "delete." You will be prompted to confirm whether or not you want to delete the file. Click the yellow Yes, delete permanently" button to remove the file from your library.
If you don't get satisfied with the solutions, you can go for the professional help by just visiting here :
www Kindle Com Support
2answers
I want to delete books on my kindle?
I know the most comprehensive ways of delete books from Kindle Check out this post How to Delete Books from Kindle Devices APP
3helpful
3answers
How do I delete a book from my device that I have finished reading?
To remove a book or magazine from your Kindle Fire HD libraries, follow these steps:
  1. On the Home screen, tap Books or Newsstand to display your library.
  2. Locate and press your finger on the item you want to remove. A menu appears.
  3. Tap Remove from Device press the helpful button
How to delete books from Kindle Fire HD
How to Delete from Kindle Fire
How to Delete Books and Docs From Kindle Fire HD8 HD10
2answers
How do I delete a book in my library?
If you have piles of books in your iPad, you may want to delete books from iPad to free up iPad storage space. The easiest way to do that is deleting books in iBooks app. You need to go to iBooks app, and tap Select at the upper right corner. Then select the books you don't need and tap Delete at the upper left corner.
If you have many ebooks to delete, deleting books in iBooks app may be a little complicated. So you can re-sync iPad with iTunes to delete books from iPad. This is also is easy to be done, and you only need to connect your iPad to computer with USB cable, and sync iTunes Books library with iPad. After that, you'l get the books from iTunes library to iPad. delete-book-in-library-oxaxc0rwhkhzilrwacqreyis-5-2.jpg
Get more information here.
http://www.leawo.org/tutorial/how-to-delete-books-from-ipad.html
I inow how to delete a book but then it goes to archives. how do i delete it permanently
Here are some links. Basically you have to go to who you bought books from and erase from there. Which means if you want book in the future you will have to purchase again.
How to Delete Books From Kindle
How do i delete a book from my ipad?
Books can be deleted, when you are in the iBook app. Select a folder where books are. then on the line of a book swipe to the left and press delete when you see it.
or on the right top of the page you see select (not in a book, but in a folder) click select. on the left side of all the books you no see a little cyrcle. tag the circle from the books you want to delete. on the top left, you now see delete. press there and acknowledge.
How can I delete a Google play book?
Contact Google on how to delete books.
2answers
How do I delete a book once I have read it from the nexus 7
What App are you using? Kindle or Play Books? I'm not sure about Kindle but in Play Books you tap on the books settings and select "Delete from Library". The settings tab is a line of three vertical dots on the lower right side of the books icon.
Hope this helps.
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
