Push pull switch is broken. Can turn it on by holding the inner switch but the chrome outer sw is stripped an spins on shaft.
Washer Start Button Replacement -GE Top-Load Washing ...
? 2:05
https://www.youtube.com/watch?v=tEVwT4mL9ZU
Sep 27, 2012 - Uploaded by RepairClinic.com
This video provides step-by-step repair instructions for replacingthe start button on a GE top-loading washing ...
Cabrio Washer Start Button Broken Quick Fix - YouTube
? 5:54
https://www.youtube.com/watch?v=h1CRcehOCxY
Mar 23, 2015 - Uploaded by FreidasGarden
This video is about Cabrio Washer Start Button Broken QuickFix. I hope it helps you get some wash done
Testimonial: "This is a switch that clicks as you turn it into the desired cycle. It is not a "button""
Shop for Dryer switch on Google
Huebsch #70455101 Washer/Dryer SWITCH,ROCKER (DPST OFF-(ON))
Huebsch #70455101 W...
$10.56
Google Trusted StorePWS Laun...
GE Dryer Rotary Start Switch, Black
GE Dryer Rotary Start S...
$6.44
Walmart
GE Rotary start switch - WE4M519
GE Rotary start switch ? WE4...
$7.80
Google Trusted StoreAppliance...
Dryer Push-to-start Switch - 3398095
Dryer Push?to?start...
$33.64
Sears Parts D...
Whirlpool Dryer Door Switch 3 Wire - 3406107
Whirlpool Dryer Door Switch 3...
$14.39
Google Trusted StorePartSelect
Whirlpool® Dryers - Whirlpool.com
Adwww.whirlpool.com/Dryers
Care for the Ones You Love with a Whirlpool® Gas or Electric Dryer.
Dryer Switch 3406107 - Amazon.com
Adwww.amazon.com/Home-Appliances
Save on Dryer switch 3406107! Free Shipping on Qualified Orders.
Cyber Monday Week Deals · Give The Gift of Prime · Kindle & Fire Gift Ideas
Quick tips....Slow or
no spin....
Lid open.
Lid switch defective. ( Very
Common problem )
Lid switch disconnect plug
open/burnt.
Clothes between basket and
outer tank.
Lint filter caught between
the wash basket and outer holding tank.
Wiring harness.
Bad motor capacitor ( How
to check )
Weak clutch.
Timer switches. (
possible not allowing the pause required for the transmission to set up to
spin )
Motor.
Cam driver on basket drive
broken or basket drive weak.
Spin tube.
Notches in drive block worn
out and not engaging basket drive shaft.
Broken motor coupling. See
Replacing Motor Coupler Page
If your washer will not spin...first thing is to consider
if washer is RUNNING and not spinning or NOT RUNNING and not spinning. If the washer is
NOT running ( or working intermittently ) check lid switch for continuity.
Broken lid switch arm and the lid switch probe should be checked as well.
Something NEW to check for when looking at that lid
switch. Always a good idea to check for clothing between the tanks as well.
Make sure nothing has gone through one of the inner basket holes and is now
scrapping or jamming the tub from moving, such items may be a nail, pin, bra
under wire.
Read
a bit on how the washer works as well.
If washer IS running, remove
power and remove cabinet. Use a piece of insulated wire to by-pass the lid
switch wires, turn the timer to spin and pull out the knob, push the knob back in and pull
it out again. Watch for the clutch drum to turn ( brown section in picture A ). If it is turning but the inner wash tub is not,
then more often than not you have a worn clutch lining or a weak spin spring, also the
brake may have seized up. If the clutch drum is not turning and washer is not spinning, often
the failure is in the transmission gear box. ( see picture B ).
