Question about Pride Health & Beauty
Scooter is saying error code 8 which is motor does anyone know what this could be please?
Posted by Linda Fisk on
  • Rob Hill
    Rob Hill Feb 18, 2018
    Normaly it a related code for a fault with the motor, check connections first to the controller, then check the brushes making sure the brushes can be removed easily, if not thats the fault as it not connecting with the coummutator correctly.
Claude Kayser
    Top Expert:
  • Pride Master
  • 9,098 Answers
Pride Mobility Products Victory 9 Scooter 4 Wheel Error code
www.fixya.com > ... > Pride Mobility Products Victory 9 Scooter 4 Wheel
Pride Mobility Products Victory 9 Scooter 4 Wheel, error code related issues. ... Question about Thermometer Mobility Scooters ... error code is 8 Error code 8 means an internal controller error or problem and requires replacement of the controller. ... Theysay there is no listing for code 9 I have replaced the batteries,checked .
Basic Troubleshooting Instructions - Pride Mobility Productswww.pridemobility.com > Resource CenterPride MobilityScooters. INFINFB2040 Sonic Troubleshooting ... Chargers. INFINFB2586 Charger Indicator Codes ... Disclosure Statement Pursuant to Cal. Civ. Code 1714.43(a)[PDF]Legend Owner's Manual - Pride Mobility Products
Posted on Nov 28, 2015
Testimonial: "Thank you it is a Pride Executive and in my manual says code 8 is motor but just wondering what could be wrong with it"
  • Claude Kayser
    Claude Kayser Nov 28, 2015
    www.pridemobility.com › Resource Center
    Pride Mobility
    Pride Mobility Products Corp. Close .... Chargers. INFINFB2586 Charger Indicator Codes ... Disclosure Statement Pursuant to Cal. Civ. Code 1714.43(a)
    [PDF]Any electromechanical device requires occasional ...
    www.pridemobility.com/download.php?f...Jazzy...pdf
    Pride Mobility
    www.pridemobility.com. INFINFB2047/Rev ... It takes 8-14 hours to fully charge a depleted set of batteries ... Determine if the controller is flashing a fault code.
Can anyone help my mobilaty scooter is a kymco maxer it has come up with error code 2 does anyone no what this means
Error code 2 is a motor fault, normally brushes. Companies charge a call out fee to send an engineer to you or you can always send it back yourself.
May 24, 2018 | Kymco Motorcycles
I HAVE A CRAFTMATIC COMMANDER MOBILITY SCOOTER I NEED A MANUAL PLEASE, ALSO DOES ANYONE KNOW IF IT 8MPH CLASS 3 OR NOT..THX
hi, it 's actually made by pride and yes it is a rated class 3 mobility scooter capable of 8 mph...
  • Pride Craftmatic Commander (CRM2700)
Regards
Rob
Apr 27, 2016 | Health & Beauty
I have error code 9, no one knows what that code is?They say there is no listing for code 9
Error 9 possible Solenoid Brake Trip
The parking brakes have a bad connection. Check the parking brake and motor connections. Make sure all the system connections are secure.
May 14, 2015 | Ev Rider Powerful Mobility Sport Rider 20k...
8 FLASHES
Hi, this is the official advice given, please let me know how you get on
8 Motor Volts The motor is not connected to the controller, or there is a short-circuit in the
motor connection. The scooter does not drive.
• The motor brushes may have lost connection. Turn the wheels of the
scooter to reconnect the motor brushes, and then turn the controller off
and on. If this happens often, the motors may be faulty.
• Check that the motor cables are not loose or damaged.
Regards
Rob
www.gewizrepairs.co.uk
Feb 28, 2014 | Invacare Atm Take Along Chair - Red
Scooter battery shows full charge but scooter does not move ! red led light flashes 8 times !
Plamont unfortunately that flash code usually means a controller error. The controller is the brains of your scooter. Take the seat off and remove the rear shroud that covers the batteries and motor/gearbox assembly. Check all the wiring connectors for damage or loose connections. After checking the connectors turn the scooter on and see if you still get 8 flashes.
Did Medicare purchase the scooter? If so they will pay for most of the repair costs. You can contact your provider that sold you the scooter or a repair service Repair [email protected] 1-877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 Hope this helps you
Sep 12, 2010 | Golden Technologies Liteway 3/4 Wheel...
Scooter moves approx 10 feet then stops led flashes 8 times then stops
Hi. 8 flashes is a fault code for a motor fault. It will be either worn brushes in the motor or faulty connectors to the motor. This fault code means that there is no circuit through the motor. Probably time to overhaul the motor. Most mobility scooters have plugs and sockets that are really to small to carry the amount of current that they do. Because of this, they sometimes fail.Good luck. Neil.
May 21, 2010 | Invacare Supply Group Invacare Lynx Large...
Hogh - low speed switch is incorrectly wired , but i dont know how it should be wired - Pride Hurricane scooter
Hi, I take it been taken then, do you get a error codes ?
see below
DIAGNOSTIC FLASH CODES
The diagnostic flash codes for your scooter are designed to help you perform basic troubleshooting quickly and
easily. A diagnostic flash code will flash from the status LED in the event one of the conditions listed below
develops.
NOTE: Your scooter will not run unless the flash code condition is resolved and the scooter has been
turned off, then turned back on.
Any electromechanical device occasionally requires some troubleshooting. However, most of the problems that
may arise can usually be solved with a bit of thought and common sense. Many of these problems occur because
the batteries are not fully charged or because the batteries are worn down and can no longer hold a charge.
FLASH CODE CONDITION SOLUTION
! (1) Battery charge is low. Charge batteries as soon as possible.
! ! (2)
Batteries are too low to operate the
scooter.
Charge batteries.
! ! ! (3)
The scooter’s battery voltage is too
high to operate the scooter, or the
charger is still connected to charger
port.
Unplug charger and/or turn key off, then
back on again.
! ! ! ! (4) Current limit time out.
Turn the scooter off for a few minutes,
then turn your scooter back on.
! ! ! ! ! (5)
The manual freewheel lever is in the
(forward) freewheel position.
Remove the key from the key switch,
then push the manual freewheel lever to
the (rear) drive position, and restart your
scooter.
! ! ! ! ! ! (6)
Throttle control lever not at center
position at start up.
Return the throttle control lever to center
position, turn scooter off, then back on.
! ! ! ! ! ! ! (7) Speed pot error.
Contact your authorised Pride Dealer for
assistance.
! ! ! ! ! ! ! ! (8) Motor volts error.
assistance.
! ! ! ! ! ! ! ! ! (9) Other internal errors.
Regards
GeWiz.
Oct 20, 2009 | Pride Hurricane 4 Wheel Personal Mobility...
Health & Beauty Logo
788 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
