Question about Samsung RS2630SH Side by Side Refrigerator
Which colored wires go to what on the compressor starter relay
  • Samsung Master
  • 4,656 Answers
Here is a service manual=> RS2630SH Service Manual
APPLIANCE 911
Posted on Nov 29, 2015
Fuel pump relay location 93 dodge spirit 3.oL
Under hood, driver side fender lining, may be a relay pack, note the wires colors in diagram to find fuel pump relay. Compare wire colors on relay connector. Just my opinion.
Mar 27, 2018 | Dodge Cars & Trucks
The wire color that actually sends the voltage from key to starter
Without more information regarding make model and year that's a tough one to answer.Most vehicles lately use a starter relay so there is no wire that goes directly from the ignition switch to the starter,it would go from ignition switch to a neutral safety switch then perhaps a anti theft device then to the starter relay,then the starting wire would travel from the starter relay to starter.In older gm products the common ignition to starter wire was purple for years.
Apr 28, 2017 | Cars & Trucks
Hi I have a Westinghouse 614 fridge/freezer compressor is not working and l found that starter relay was faulty changed it but still no go. there are two wires one blue and one white l believe blue was...
I believe the actual colors should be re for run windings and white for start capcitor and green or brown or black for ground.
AT TIMES YOU MAY HEAR THE COMPRESSOR CLICK OFF AND ON OVER AND OVER. Signs of a bad start relay or capacitor. Check with an OHMS meter for continuity (ohms) and voltage, capacitor can be checked for Microfares.
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, somes located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur srtart winding, 1 goes to ur run winding and the center goes to ur ground.
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
Mar 02, 2015 | Westinghouse Refrigerators
Starter relay gone bad on my 90 toyota, have a new 12 volt, four point 30 amp univerisale relay with numbers reading 85,86,87,30..what color of wire goes to number on relay?
If you look at the relay it has a wiring diagram on the side of it, showing the power wires (recall 87 being one of them) and the control wires. Can't tell you color, perhaps a Toyota tech could but in my experience they vary.
Nov 22, 2013 | 1990 Toyota Pickup
Do you know where I can get a wiring diagram on a whirlpool side by side refrigerator model no ED5PHEXMB00? Mainly for the compressor. Freezer is not getting cold. I vacuumed the coils in front and...
Hello Thayden,
I understand that the Refrigerator compressor is not working on your unit. There are three possibilities of why the compressor is not working, the compressor is bad, the starter is bad, or the capacitor is bad.
To check the starter you will need to do the following (most common): Refer to picture at the bottom of the post
1. Unplug the unit
2. On the side of your compressor there is a cover this is the starter relay cover.
3. Remove the cover
4. Remove the wires
5. Remove the starter (top piece stuck on two rods)
6. Check if bad (shack it if you hear a noise/knocking it is bad and will not allow compressor to start)
7. Replace it and the bottom one the over load.
8. Reinstall in reverse
The Run Capacitor (uncommon that they go bad but possible)
1. The little black or silver box that two wires run to from the starter
2. Check to see if contacts or unit is burnt.
The Compressor
1. If you replace the above items and the compressor is not running the the problem is the compressor. This will take a licensed HVAC person to replace.
The above parts are inexpensive between $30-$50 at your local appliance parts store. There is a 50/50 chance that this will work and save you the cost of replacing the compressor or the whole refrigerator.
Thank you for choosing FIxYa.com
Justin
pd_0046_106_4387835?$pddetailsth$
Above Starter/overload and cover replacements (starter is in the bottom middle that you shake to see if you hear a noice/clicking)
Starter relay box on the left side of the compressor in this image.
Apr 05, 2011 | Whirlpool Refrigerators
Is there a resistor or relay switch that sends power to start compressor
There is probably an a/c clutch relay in the fuse and relay box. The most common reason for the a/c clutch not engaging is a low charge though. Have you hooked gauges up?
Jul 31, 2010 | 2000 Dodge Durango
Refrigerator Model #KSRA25ILSS03. How much and how difficult is it to replace a starter relay?
a 3 in one start relay usually runs about $75 and it is not that difficult to replace if you are sure that this is the problem there is also the chance that the compressor could be damaged. you do not want to replace just the relay as there is also an overload circuit the 3 in 1 starters have everything in it and good instructions as far as which wire goes where you have 2 wires for 120 volt in and then three connection on the compressor
May 15, 2009 | KitchenAid Refrigerators
Replacement starter relay for skybox MBV1976A...
i lost track of the way the wires go on starter relay. can someone please let me know or send diagram, for the 3 wires. Any help would be appreciated.
Jul 04, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Frigidaire refrigerator
check the overload, take it loose and inspect it for a burnt spot shake it if it rattles replace the relay
you either have a relay bad or a stuck compressor
the compressor has a 5 year warranty on the part, the relay 1
so if you relpace the relay and it still doesnt run the compressor, call for serviece under warranty
Apr 27, 2008 | Frigidaire FRS26R4A Side by Side...
Samsung RS2630SH Side by Side Refrigerator Logo
267 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Gerry Harvey
Gerry Harvey
jasbo
jasbo
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
