Question about Sanyo Televison & Video
How to get Sanyo dp50741 out of hotel mode?! - Sanyo Televison & Video
  • 744 Answers
This is for Panasonic but might help you
Getting out of the hotel mode is very easy. Just go get the Panasonic remote and open your tv. Go near the tv and hold down the AV/- button on the television itself. Then use the remote and press the AV button for 3 times. A hidden menu on the television screen will appear. Turn off the "Hotel Mode" from the menu and exit. Do not touch anything from the hidden menu except the hotel mode. Now you can use your tv in normal mode. The remote is required to access the hidden menu so be sure your remote is working and has working or full charged battery before doing the steps above.
Read more: My 50" sanyo plasma tv is stuck in hotel mode how do i get it out of hotel mode? - When i turn the tv on it says D01--32 and a blue lower case u under it :: Ask Me Fast at http://www.askmefast.com/My_50_sanyo_plasma_tv_is_stuck_in_hotel_mode_how_do_i_get_it_out_of_hotel_mode-qna4904417.html#q5129429
Posted on Nov 28, 2015
rsk571977200
  • 7 Answers
SOURCE: I need a repair manual for a Sanyo tv model
Go on sanyos website and download the manual
Posted on Oct 31, 2014
I have a Sanyo and it is.stuck in hotel option menu
If you wish to get some details; visit the site linked here. Pull up older posts.
Search the site by type in "Hotel mode" as keyword, in the search box at the top right of the home page, to get related posts easy. You might have to enter its service mode option to change this hotel mode selection to normal mode. Service mode entry, adjust and exit procedure to many popular brand TVs are given in that site. Never forget to exit the service mode, after all adjustments have been done.
Sep 02, 2017 | Sanyo Televison & Video
Sanyo 50 tv DP50741 speakers quit working
Make sure your audio setup hasn't changed. You can select where the audio goes in setup. If everything is correct, then the main board needs to be replaced. You can get it here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Dec 05, 2016 | Sanyo Dp50741
I have a Sanyo DP50741 tv. Sound will not work. Picture is find. How can I fix it?
Make sure the audio is not set too low or mute is on, then try plugging in headphones to the audio jack.
Jan 22, 2016 | Sanyo Televison & Video
I have a sanyo dp50741 the wife was watching it today and it just up and shut off and now won't turn back on
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
May 07, 2014 | Sanyo Dp50741
Led blinking red on a sanyo dp50842
How many times this standby/power light blinks at one time switch ON?Count it carefully.These blinks are fault indication, and known as blinking codes.From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV.This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Dec 05, 2013 | Sanyo Dp50741
Tuning sanyo thats in hotel mode
Going is hard----you will need the "hotel" remote which is different than a regular remote----you can try to do it via the buttons with the on screen menu but may not work that way.
Oct 29, 2012 | Sanyo Televison & Video
Sanyo tv in hotel mode
Possible only with buttons on some models to do this---usually the hotel remote is needed for this function for clear reasons--they did not want people to switch the set to this in the hotel.
MY SANYO DP50741 POWER BOARD?
i would check to see if the stand by supplies are on the power board and then check to see if the on supply comes up briefly when power is pressed it could be the power board or main board testing the supplies will narrow down which board you need.
Aug 23, 2012 | Sanyo Dp50741
Remove hotel lock
You have to get into its Service Menu option to unlock Hotel Mode. Contact any service technician. They only can do it, as entering into service mode, and adjust data values there; without any knowledge about it; might make the TV irreparable.
Jul 30, 2012 | Sanyo 21MT4 21" TV
Televison & Video Logo
271 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
