Can't hook up my sb 2920x-c6 to my auria eq 5888 tv where audio out jack
Posted by patrick scheall on
Brett Duxbury
  • 4,290 Answers
Can't find that eq 5888 model number but does the tv have a connection labelled as spdif this is a special digital audio out standard by phillips.
http://www.hardwaresecrets.com/everything-you-need-to-know-about-the-spdif-connection/2/
I am not sure if this can be plugged into the sb 2920x-c6 digital in socket or if you need a digital amplifier between the two items ?
Someone else on fixya may know if a digital amplifier is needed or a direct connection from tv to sound bar is possible via a spdif cable.
Posted on Nov 27, 2015
How do you connect an auria eq5588 tv to a bose solo 15/10 tv sound system
Make the connection to the "Variable Audio" output jack of the TV.
Sep 08, 2016 | Televison & Video
Where is pre out im having trouble hooking up amp and eq
You have to use the TAPE 2 (or monitor) on the receiver. It will take two sets of RCA cables. Both the receiver and the EQ will have an input and an output.
  • Run the output/REC (from TAPE 2) to the input on the EQ.
  • Then, run the input from the receiver (TAPE 2 again) to the output on the EQ.
The EQ will have another 2 sets of RCA jacks to hook up a second tape deck (because you used the jacks on the receiver for the EQ). You don't have to hook anything to these if you don't want to, or don't have a second tape deck.
The receiver will have a monitor button, which most of the time is labeled as TAPE 2/MONITOR. Select whatever input you want to use (CD, Tuner, Aux, etc.), then press the MONITOR/TAPE 2 button. When that is on, the EQ will be in the audio chain - you'll be able to use the EQ to adjust the sound. If you turn the MONITOR off it will take the EQ out of the audio chain - the EQ settings won't affect the sound.
Keep in mind, the EQ will also have a button to select the TAPE 2 input. If you have a second tape deck hooked up to the EQ, this is how to use it. Make sure that the tape input is off on the EQ, if you aren't listening to that second tape deck.
Mar 09, 2016 | Audio Players & Recorders
Have an AURIA EQ5588 55" TV .... would like to connect external speakers.
Only you can look at the sides and back to see if it has audio output jack , we are not there you see
Jan 21, 2013 | Televison & Video
On an auria eq4088p back panel which jacks are the audio OUT jacks
It is normally marked on the panel. The white and red RC sockets are normally the audio in/out.
Aug 28, 2012 | EQD EQ4088p LCD TV
Having problem with audio, with auria tv (when unplug headphones, sound will not come back on tv)
The socket for the jack on the set has a leaf connection that when you insert the jack moves aside routing sound to head phones and cutting it off to speakers= the socket for the jack is out of position inside, either needs to be replaced or tweaked inside just a little.
Not much else can cause this if the headphones work.
May 02, 2012 | EQD Auria EQ2488F 24 LCD TV
How to hook up external equalizer to Sony STR-DA 2000 ES. Equalizer is a Denon
you need a empty in/out tape slot (jacks in back of Sony, if tape deck is connected you can use "Y" connectors) connect jacks to EQ tape in & out.... (press EQ button Bypass)
Nov 13, 2010 | Sony STR-DA2000ES Receiver
No clue how to connect my equalizer
FOR EXAMPLE IF YOU WER HOOKING IT TO A CD PLAYER,, YOU WOULD PLUG RCA JACKS IN THE LINE OUT ON THE CD PLAYER,, THEN PLUG THEM IN THE EQ WERE IT SAYS LINE IN OR AUDIO IN,,THEN TAKE SOME RCA JACKS PLUG IN THE EQ TO AUDIO OUT, THEN TO YOUR RECIEVER,, IN CD ,,AND VISE VERSA ,,WETHER ITS A TV OR PHONO,, ANYTHING,,
Sep 25, 2008 | AudioSource EQ-100 Home Equalizer
Hi. i want to add a graphic eq to my pioneer receiver (home audio).
if the Eq has enough jacks to run every thing, that would go In to Eq an out to receiver, you were told correctly, for example cdplayer out - to Eq In - Eq- out to Receiver in
Nov 29, 2007 | Spectrum Technical Hifi EQ-B5100...
60 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
