Question about Oregon Scientific Measuring Tools & Sensors
Faded numbers on both in &bout readings.
AAlmost constant ,batteries changed but same as above.
Posted by fbrian93 on
Need the serial number to kenmore model number 363.9532783
There is no way to identify the S/N from the model number only. The model number only indicates what features were included in that model. Hundreds or thousands of that model may have been made. Unless you have the purchase receipt that MAY have the s/n on it, you will either need to work harder to enhance and read the faded label or live with the fact that the serial number is unattainable.
Sep 25, 2015 | Kenmore Washing Machines
Have a 95 ford thunder bird at idle the engine has aalmost like a skipping vibration what could this be pretty sure it's firing on all 8
It sounds like a engine ignition misfire to me, have the plugs and plug wires been replaced? If not replace them taking care to route the plug wires exactly as the factory did, replace any broken loom holders for the plug wires, this is very important.
Sep 03, 2012 | Ford Cars & Trucks
Forney model cb serial 145669 can't read front of welder.10 holes unmarked above low med hi
Here is picture of my Model CB. Based on the serial number it is slightly newer, but it should be close enough. Mine also came with a battery charger, which why it has the extra hole.11_22_2012_4_51_47_pm.jpg
Apr 07, 2012 | Welding Tools
I need the serial number for my acer laptop, however, the label on the bottom is faded and I can't read it. Where can i find that
As far as I know the only location of your serial number is on the bottom, and if the sticker is faded you may need to contact Acer, or your retailer, also try looking on your reciept.
Hope this helps ^^
Apr 22, 2010 | Acer Aspire 5100 Notebook
My caculator screen is faded, i can barely read the numbers. it s barely a year old and i put in new batteries. how do i fix this?
After the change of batteries, the screen reverted to default contrast. You should try to darken the screen.
Press and hold the [Diamond] key and tap the [+] key. Keep at it until screen is dark enough.
Hope it helps.
Oct 12, 2009 | Texas Instruments TI-89 Calculator
Display on my uniden is very faded and hard to read
The battery has a 90 day warranty, but first try resetting the phone by disconnecting the battery, press and hold * and # key while reconnecting battery. Must have receipt for warranty replacement.
Mar 12, 2009 | Uniden Cordless Phone
2003 Camry Speedometer reads 150 mph constantly.
i would disconnect the battery again let it sit for 15 minutes, i changed an alternator and jumped the car then started driving and that happened to me, 20 minutes of driving and the computer finally kicked in and started working again. good luck
Aug 17, 2008 | 2003 Toyota Camry
Caller id display screen
I can't read my caller Id Screen numbers are disappering
Jul 27, 2008 | GE 25951EE2 Phone
Measuring Tools & Sensors Logo
206 people viewed this question
Top Oregon Scientific Measuring Tools & Sensors Experts
Marvin
Marvin
Lawrence Oravetz
Are you an Oregon Scientific Measuring Tool and Sensor Expert? Answer questions, earn points and help others
