Question about GE JVM1640 Microwave Oven
G E microwave 1650ch01
Shuts down after a few seconds. readout is garbled. must reset clock etc.
Posted by paulp1000 on
  • DanPav Dec 11, 2007
    Microwave runs exactly 2 seconds and then crashes, scrambles the display and I have to reset everything (clock, date, etc.) and the problem continues to repeat.
    The microwave is only 14 months old as well...
William Miller
  • GE Master
  • 9,179 Answers
This is a due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If yours was recently replaced, it may have loose mounting nuts or bolts or the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
GE had a campaign (but not a recall, mind you!) covering several models.
Details are in their bulletin at http://207.234.249.73/mwd/ge_mw_mag_kit_bulletin.pdf
The parts kit (that GE used to pay for) is part # WB27X10489 and is shown in the photo below.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on
Fixya: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Nov 18, 2007
MY GE SPACESAVER MICROWAVE MODEL JVM-1653-SHO-1 SHUTS DOWN AND TELL YOU TO REPROGRAM THE CLOCK BUT YOU RESET USING ALL INSTRUCTIONS I INSTALL COOK TIME PRESS START IT WILL COME ON FOR 3 SECONDS AND SHUTS...
This is magnetron-related.
See
this FixYa solution (solution #2) even though your model number is different.
Jun 19, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
The readout is reading like hyroglifics?????/
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If this scrambling is occurring a few seconds after you begin
a microwave heating cycle, see this FixYa solution even if your model number is different.
Jun 15, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker jvm1650sh01 starts to microwave then loses power
See this FixYa solution.
May 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker shuts off after a few seconds and asks for the clock to be reset
Ge Spacemaker comes on ok but after a few seconds the noise level goes up significantly and it does not heat. It keeps running until the time runs out but it doesn't heat.
Feb 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker model #JVM1650CH01 that keeps on shutting off everything after a few seconds. I have to rest the clock and month -year - date to try again.
my spacemaker xl jvm 1650 microwave shuts down after just a few minutes of operation and after a few minutes needs to have a clock/time/day etc reset. is this reparable by a homeowner?
Oct 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Shuts off after maximum of 8 seconds. does heat when on.
Sounds like the controller board has failed, assuming a circuit breaker has not tripped or fuse has not blown.
If all you do is reset the clock, and then it looses time, regardless of using the microwave, then it points to the clock/controller board.
If this only happens when you use the microwave portion for a few seconds, I would be suspicious of the microwave circuit, where there are several components that could cause the failure.
Jan 22, 2009 | Kenmore 80593 Microwave Oven
SET CLOCK. TRY TO USE. IT SHUTS OFF AFTER A FEW SECONDS.
I found an envelope with troubleshooting info inside the microwave on the left side behind the front vent. A troubleshooting flowchart was included which indicates that this problem is caused by the high voltage capacitor. I got mine out pretty easy and ordered one from appliancepartspros.com for $55 (which includes expedited shipping. I hope this info helps.
Sep 05, 2008 | GE JVM1650 1000 Watts Microwave Oven
Timer Shuts off after 5 seconds
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Is it 5 seconds or 5 minutes? The difference coulsd be important, but either could indicate a bad magnetron.
Let us know if the hard reset doen't fix it.
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Nov 18, 2007 | GE JES1289SK Microwave Oven
Panasonic NN-S533WF Microwave
because of high voltage circuit thats happend ,please check highvoltage circuit may be short circuit or any companent burntout. check magnetron and high voltage diodes etc.
Sep 29, 2007 | Microwave Ovens
WHEN PRESSING COOK TIME OVEN CLICKS ON FOR ONE SECOND AND RESETS CLOCK
Please try on some other power point as if there is loose contact or sparking in point which cause to switch off as soon as you start because of heavy current drawn by oven and clock also resets. If not solved even then must have some short circuit or over loading in timer circuit or magnetron. in this case you have to call for a service engineer.
Jul 26, 2007 | GE JVM1860 Microwave Oven
GE JVM1640 Microwave Oven Logo
145 people viewed this question
Top GE Microwave Ovens Experts
Jimmy
Poppa Maddo
Poppa Maddo
gbob59
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
