Photography Logo
Question about Pentax Photography
I have a pentax zx-60 that is showing an error message o_ _ _ _ with an E on top of that. I'm not sure what it means or how to fix it. I tried reloading the film and it doesn't seem to advance.
Posted by Aaron on
Tony Parsons
  • Pentax Master
  • 6,401 Answers
I think the 'o____' is intended as a pictorial representation of a roll of 35mm film, the 'E' signifying an error in loading it. Not used this particular Pentax model myself, but some of them have a slot in the take-up spool where the 'tongue' of the film should be inserted - is that the case with yours ?
Posted on Jan 05, 2016
5 Related Answers
Anonymous
  • 619 Answers
SOURCE: Film Advancer loose
Hi., rotate the rewinder clockwise until the film will tightened , hold the film rotator , observe the rewinder knob moving , it means the film are engage will. then shoot for favorite angle.
Posted on Feb 18, 2008
Anonymous
  • 185 Answers
SOURCE: Pentax SF1
This model has a gear train from the motor to the advance sprocket. The gears are plastic and prone to strip. Try E-Bay for a reasonable replacement and keep this one for parts. There are no new parts available.
Posted on Dec 08, 2008
Anonymous
  • 185 Answers
SOURCE: Pentax mz 60 unable to load film error message
error messages are for camera repair technicians and are found in repair manuals. have your camera checked by a camera repair shop tech.i would get an estimate first.
Posted on Dec 15, 2008
Anonymous
  • 185 Answers
SOURCE: I cannot load the film
rootseya,
pentax error codes are in the repair manual for camera repair technicians. the camera needs repaired.take or send your camera to a camera repair shop for an estimate.
Anonymous
SOURCE: Pentax zx 50 35mm slr
Others here have suggested the problem lays with the plastic gear on the advancing motor beside the mirror.
This might cost $100 or so...?
Posted on Jan 24, 2009
Lens error
This is probably THE most common failure among digital cameras.
There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
1helpful
Lens error 0411000
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
I have a pentax zx-60 and i am taing a photo class how do i set the camera on maual but still be able to change the aperture
Use the exposure mode to metered manual mode using the [mode] button until the [M] is selected on the far right of the LCD screen.
The [M} is to the right of the [Tv] and [Av] selections.
Also, there is a switch on the camera body where the lens is attached... switch from AF to MF (UP position) (AutoFocus to ManualFocus).
The meter inthe viewfinder will continue to work so that tou can use the built-in meter to assist in your manual configfuration.
Good Luck! Photography is a great hobby and profession!
I have a pentax zx-60 and when i turn it on all it says is av and i am trying to get it to say manual how do i do that
I love my Pentax!
Use the exposure mode set to metered manual mode using the [mode] button until the [M] is selected on the far right of the LCD screen2.gif.
Also, there is a switch on the camera2.gif body where the lens is attached... switch from AF to MF (UP position) (AutoFocus to ManualFocus).
My film won't load
Jammed Advance Motor Assembly.
I cannot load the film into my pentax mz 60 it keeps showing the error message. I have no trouble loading the film into my second camera (same)
rootseya,
1helpful
2answers
Av is flashing
Make sure the aperture setting on the lens is set to "A". Solved the problem.
Top Pentax Photography Experts
Steve
Are you a Pentax Photography Expert? Answer questions, earn points and help others
