Apple iPad (16 GB) WiFi Tablet PC Logo
A
Anonymous Posted on Nov 26, 2015
Mac Mini Ipad Locked screen?
Locked Ipad 2 screen is locked and I can not slide it open. It give me a error message to press a button or slide it open but nothing happens...?? I can not get anything to work.
nhnonna
Level 1:
Problem Solver:
  • Contributor 29 Answers
  • Posted on Mar 02, 2016
nhnonna
Contributor
Level 1:
Problem Solver:
Answers
29
Questions
Helped
3394
Points
30
Press and hold down the Home button on the front of your iPhone, iPod touch, or iPad while still holding down the On/Off button. Keep holding both buttons as the screen turns off keep holding both buttons until the turns back on again and displays the Apple logo
5 Related Answers
Anonymous
  • 71 Answers
  • Posted on Oct 27, 2010
SOURCE: how do you unlock a locked ipad screen
If you have forgotten the code, you can unlock the iPod by doing the following:
Connect your iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked. If you can't unlock iPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. If you want to change the primary computer that your iPod is associated with, do this: 1. Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data. 2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize. Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the iPod, which will erase all music and data."
Anonymous
  • 22 Answers
  • Posted on Dec 28, 2011
SOURCE: my iPad. Screen is locked
What part and how-go to my service pages and my team will be on the job
Anonymous
  • 4961 Answers
  • Posted on Aug 19, 2012
SOURCE: how do I unlock a locked up ipad?
If you've got a locked up iPad app or otherwise misbehaving iPad, and want to reboot / reset your iPad, simply hold the sleep and home buttons together until the iPad restarts.
You'll see the shutoff slider come up first, but just keep holding. The screen will go blank and the Apple logo will reappear as the iPad reboots.
Note: this does not reset any data on your iPad. This is just a restart, equivalent to rebooting your computer.
John mullen
  • 296 Answers
  • Posted on Jul 06, 2014
SOURCE: How can I get my screen orientation on my ipad 2 to work?
It's the two position slider switch on the side of the ipad above the volume controls. You go to Settings>General> Use Side Switch and put the check mark to "Lock Rotation".
epicshooter
  • 15 Answers
  • Posted on Sep 15, 2014
SOURCE: How do I restore my sound on my ipad?a
Try the toggle switch on the side above the volume rocker. This can be used to either lock the screen in landscape or as a mute toggle.
2answers
2answers
How can I activate an iPad mini that is iCloud locked
I would go to an Apple Store and ask for help.
kolbrun
2answers
How to set up password on my new ipad mini
The following can be done on ipad with iOS 8:
1. Press the home button( the round button on the front side of your ipad), to go to the home screen.
2. Find the Settings icon ( looks like gray clockwork gears) and tap on it to launch the Settings app.
3. After settings app is started try to find on the left side of the screen Passcode ( has a red lock icon near the text) and tap on it
4. In the passcode setting screen you can choose the type of passcode with the Simple passcode setting switched on or off ( simple means a 4 digit number, not simple means any character combination
5. By taping on Turn passcode on you can enter your passcode. Be carefull not to forget your passcode, otherwise you will not be able to use your ipad later.
2helpful
4answers
How do i unlock my ipad i bought it used and i dont have a password and now it is locked and asking for password
You will have to restore it by connecting to iTunes on your computer. That will erase all settings including the password. If you have a backup you can get it then set up as a new device with a new password.
2answers
How can I delete my data from an iPad 2 whose display is black & unreadable?
Hi David,
I think this will help you please refer to below steps:
  1. Make sure the iPad battery is charged above 20% ( we would recommend at least 40 - 50 %). If you are not sure charge you tablet for at least 30 -40 minutes.
  2. Make sure iTunes is not running on your computer but is ready to be run.
  3. Temporally disable firewalls and other security software to prevent interference with iTunes.
  4. Make sure your tablet is disconnected from the dock or USB data cable that equips the gadget . Nevertheless USB cable must be plugged into your PC or MAC.
  5. Make sure your PC or MAC is awake and its screen saver is turned off.
  6. Simultaneously press and hold down the Wake/Sleep button and the Home button and wait until "slide to power off" screen appears. Don't do anything after its appearing, just keep holding Wake/Sleep and Home buttons until Apple tablet will power off.
  7. Release the Wake/Sleep button once Apple tablet is off , but continue to hold the Home button
  8. Holding the home button, connect the USB data cable to iPad. When you reconnect the USB cable, tablet should power on and you should see a message on your PC/MAC display saying that iTunes has detected an iPad in Recovery Mode
  9. After you detected this message, release the home button and press OK on iTunes pop-up to confirm the restore option.
  10. Do not touch iconic tablet and you computer while iTunes downloads and installs the fresh copy of firmware on your iPad. You will be notified by iTunes when iPad is successfully restored, but... in a while, you will get an message saying that the iPad isn't recognized. Don't panic. This is because all user content on iPad including activation status was erased during restoration.
  11. Disconnect iPad from iTunes ,unplug from computer and turn off.
  12. Turn iPad on and using iTunes activate it on any computer you have. Apple currently allows up to 5 computers to be authorized for each iPad.
How to reset apple ipad
Hi Anonymous,
I think this may help you,
How do I reset my ipad
Hi Anonymous please follow these steps:
Android version 4.2. 2, user manual
When you are sure you did not make any error with your login and password, the only one to help you is Apple. When your iPad (mini) is locked on the lock screen and nothing helps, not even resetting and log in again, take the iPad to an Apple store. Take the iPad, your invoice of the iPad and identification, to prove it is your name on the invoice and ask them to help you resetting the iPad.
First try resetting, by pressing the home button and the on / off switch, till the apple logo appears on the screen. Then try logging in with the Passcode or the password you gave Apple when you did setup your account. Could be a different (actually it should be different) from the e-mail account your account is connected to.
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
