Computers & Internet Logo
A
Anonymous Posted on Nov 26, 2015
Touchscreen stopped working - Gateway Computers & Internet
Big Steve
Level 3:
  • Gateway Master 1,087 Answers
  • Posted on Nov 26, 2015
Big Steve
Gateway Master
Level 3:
Answers
1087
Questions
0
Helped
245069
Points
2442
1. turn off computer, wait 15 secs and then re-boot
2. Check for and install any Windows updates
3. Configure the touch display to identify your screen as a touch screen.
4. Search for and then select Tablet PC Settings from the results list.
This will vary with your model and Windows version. You are looking for SetUp of your touchscreen and Settings
Testimonial: "Hi Steve, not very computer savvy, how do I do number 3?"
I have an ASUS laptop with Windows 10 and my touchscreen has stopped working. I reloaded windows as I found the HDI driver for the touchscreen was ghosted-no luck. Still no driver for the touchscreen
device manager does not uninstall programs
you have to go to control panel select programs , select uninstall and then highlight program to be uninstalled the click on uninstall.
try to find the touch screen and then click on properties , find the driver tab and click on upgrade driver .
you could always go google and type in --user manual for asus touchscreen laptop--- and down load the pdf version
what you want may be included in the manual
My v touch pro touch screen wont work
b> The Touch Pro2, manufactured by HTC, is a smartphone designed to be used with the Verizon wireless phone network. This smartphone combines a cell phone, PDA, MP3 player and wireless Internet access into a small, portable device. If the device begins malfunctioning or freezing, you can perform a soft reset. A soft reset does not delete any of your saved information. It shuts the phone down and reboots the phone to the Verizon Today Welcome Screen.
Pull the stylus upward to remove it from the side of the phone. Push the back cover upward using your thumbs until it pops from the back of the Touch Pro2 phone. The back cover can then be lifted away and removed from the phone. Press the "Reset" button, on the upper, left side of the back panel using the stylus tip. The device will now restart and display the Verizon Today screen. Snap the back cover back onto the back of the phone. Touch Screen is Not Working
As most tablet PCs ,Phones and Mp3 players are full touchscreen devices, you use your touchscreen for everything you need to do on your Tablet PC. If the touchscreen stops working, you can't get much use out of your Tablet. Touchscreen issues are caused by hardware or software problems, but check with your manufacturer before attempting a DIY repair.
Hardware Issues Damages to the surface of your Tablet PC can cause the touchscreen to malfunction or stop working entirely. For example, putting pressure on the screen, such as placing the Tablet PC in a bag with other heavy items, can cause cracking along the screen. Exposing the screen to water, even in small amounts, can cause the electrical system within the touchscreen to malfunction. If the electrical system malfunctions, the touchscreen stops working properly. b> Screen Sensitivity b> Pressing the touchscreen on your Tablet PC sends a signal to the internal motherboard. The motherboard then transmits to other components, such as the hard drive. The accuracy of the touchscreen depends on the screen's sensitivity. Many Tablet PCs include a program for calibrating the touchscreen. This program may fix minor responsive issues. Even a small amount of dirt or debris can effect how the touchscreen responds. Cleaning your touchscreen with an electronics cleaner or a microfiber cloth may help improve sensitivity. b> Software Issues b> A driver is a software program that interacts between hardware devices and an operating system, Your Tablet PC needs the right drivers for your OS to work correctly. Outdated or missing drivers can cause the touchscreen to work improperly, or not respond at all. Visit the manufacturer's website to find the right drivers for your Tablet PC. b> Repair b> While you can perform some minor repairs yourself, such as re-calibrating the touchscreen sensitivity or installing drivers, only perform a hardware repair if you have a good working knowledge of electronics, specifically Tablet PCs. Before attempting to repair your device, contact your manufacturer. If your Tablet PC has a warranty, completing an unauthorized repair may make you ineligible for claiming that warranty. Hope this helps
b>
1helpful
Touchscreen has stopped working on the tablet I
its a software problem try reinstalling the software
LG Incite touchscreen not responding
try to reset the phone by picking the reset hole on the side of the phone (i use a staple) the touchscreen should be a bit better to press the unlock button. hope this helps!
1helpful
2answers
Xenon Touchscreen stopped working
There is no way. My touchscreen has stopped working several times and everytime fixes itself after a few hours. DO NOT let this phone ANYWHERE near moisture or water, the touch screen is very sensitive.
2answers
Touchscreen not working
You may be able to go the TomTom website and download the last update programming. If the problem is software this should fix it.
Iphone touchscreen not working
try fully charging the battery
Fujitsu p1120 touchscreen not working
Before you open up your computer, try downloading the touchscreen drivers from Fujitsu's website and re-installing them. Sometimes they just get flaky.
1helpful
2answers
Palm 600 touchscreen
My Palm 600 touchscreen stop working after i dropped it and now the screen when i turn it on the screen it blue and orange
1helpful
3answers
Some where else in this site it said to hold the menu and map button while powering it on. I did that and it fixed my touchscreen problem, however I did loose all data, but I have that saved on my PC.
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
