Apple iMac G5 Desktop Logo
D
David Kilpatrick Posted on Nov 26, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to delete photos from iPhoto? - Apple iMac G5 Desktop
David Payne
Level 3:
Top Expert:
  • Apple Master 14,162 Answers
  • Posted on Feb 12, 2016
David Payne
Apple Master
Level 3:
Top Expert:
Answers
14162
Questions
0
Helped
2998233
Points
455836
Does my Maxtor back up my iphotos?
Run a time machine backup. Then the easiest way would be to find a photo that you are willing to delete in iPhoto.
Jot down the name of the photo file, delete it. Then empty the trash.
Then go into time machine, try to search for that file, when you locate it, restore it. If you can then there is probably a good chance that you time machine backup is good.
To be on the safe side why not create a manual backup.
You'll find the iPhoto Library at:
/Users/username/Pictures
"username" will be your name that appears when you login to the computer.
  1. To get there, double-click the icon for your hard drive to open it, then double-click the Users folder. Double-click your Home folder, which is identified by a house icon and your username, and then double-click the Pictures folder to open it.
        1. Inside the Pictures folder you'll see a file called iPhoto Library. Copy the iPhoto Library file to a location other than your hard drive, such as your Maxtor external hard drive.
3answers
I cannot open iPhoto
You could try iphoto library manager available from http://www.fatcatsoftware.com/iplm/ you can try before you buy and it may repair the iphoto library. Hope this helps.
2answers
I want to download photographs from my iphone?
Plug in your iPhone to your computer, if it's a PC you will need to use the Photo Import Wizard and if it's a Mac you will need to open iPhoto.
I have a 4 GB memory card on my Lumix camera. I have downloaded all videos and photos to my iPhoto on my MAC, but the memory card keeps saying full. There is nothing on the camera as far as I can see. ...
Hi, did you click the option to erase the photos from the card after you imported them into iPhoto? It could be that the images are still on the card and that iPhoto has just deleted the directory.
If you are sure that the photos are all on your Mac then the best thing is to use the camera's menu and reformat the card.
I have made a point of NEVER letting iPhoto delete the pictures but I delete them manually in the camera once I know they are safe in iPhoto. However, I am finding that I am no-longer deleting the photos from the card - when it is full I put it aside and use a new one - they are so cheap now - way cheaper than film is.
I have a 250gb G-Drive with 10.4 iMac and have transfer photos from iPhoto Library to the G- Drive to give more room in the library. Now I am trying to delete the photos still in the iPhoto Library that...
1. Drag or export the photos to another device and delete the originals out of I photo. The problem with this is that you will no longer be able to revert those images to your originals. Using the export function for this gives you more options than drag and drop.
2. Hold down the option key when you open I photo will allow you to create a new I photo library on an external drive hooked to a USB. This means you have all the options of I photo, while storing the images somewhere else.
3. Copy and paste your entire existing I photo library to an external USB drive, then delete as much of your old library as you wish which could be all of it. Do this from your pictures folder on your hard drive, not I photo itself. This option allows your photos elsewhere while preserving all the I photo functions including your ability to revert to original.
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Facebook log in problem Error 101 (net::ERR_CONNECTION_RESET): Unknown error.
Thank you for visiting Fixya forums.
There are several reasons you may be getting this error code. Each will be suggested below:
Firewall
Change your firewall settings in the Security Preference Pane to 'Allow all incoming connections'. Check to make sure you don't have a firewall running that has stopped iPhoto from communicating with Facebook.
Cookies
This error code may be an issue with the cookie that Firefox or Safari uses to store the Exporter's login info. You need to delete the Facebook cookie called "isfbe". In Firefox you can do this by going to your preferences, clicking on "Privacy," then find the Show Cookies button. Find the one whose name contains the term "isfbe". Then click Delete Cookie.
For Safari you also go to preferences, but first click on "Security," then click Show Cookies and find the aforementioned cookie and delete it.
After this, just go back to the Facebook Exporter in iPhoto and login again, this time you will have no connection problem.
iPhoto
iPhoto, a problem lies in a conflict with the latest point update for iPhoto '08, version 7.1.3. Maybe it will work if you reinstall iPhoto, update to 7.1.2, copy the iPhoto application and rename it "iPhoto old," and then run Software Update and bring it up to date to get the bug fixes in the latest update for your main copy of iPhoto.
Note: I don't know if it will change the library format at all with 7.1.3.
The FAQ/support page for the Facebook Exporter for iPhoto is here: <http://www.facebook.com/help.php?page=718>
Login
1. Log out of Facebook through your web browser.
2. Go to Facebook Exporter for iPhoto, click Login.
3. This will open a Facebook login page in your web browser.
4. Log in but do not check "Save my login info..."
5. Go back to iPhoto, hit continue, and export your photos.
Sometimes an error message may still occur while uploading the photos, but retry and eventually it should work.
LittleSnitch
If you have Little Snatch running on your computer it may be blocking iPhoto from access port 80.
For some reason with the Facebook export it doesn't pop up and prompt you to allow access. Allow access in LittleSnitch my Facebook plugin for iPhoto may allow you to start connecting properly.
FULL Reset of Safari
You can remove all history, cache, cookies, etc.
Firefox History
If your browser is Firefox, clear history.
How do I select a series of photos in iPhoto in order to delete them all simultaneously?
I would flag the photos. You do this by selecting a photo and then using the command under the photo menu or on the iphoto dock. Once you have flagged the photos you want to delete, go to the flagged items under the library and then select all and then hit the delete key. Hope this helps
Nikon D70 duplicate photo
Sounds like you protected the picture. Either unprotect it first, or else just format the card.
27helpful
4answers
Deleting pictures from my phone's photo albums
These are all "closing the door after the horse has bolted" - suppose your iphone already has photo albums you don't want. How to delete them??
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
