The FL (Over Fill) error code indicates that the flood pressure switch is open (tripped). It is likely that you are getting the LD (Long Drain) fault code
because the control detects that the flood pressure switch will not
reset after running the drain pump. Your likely failure is in the flood
pressure switch
Tapping on the flood pressure switch with the handle of a screw driver
may reset it. Reassemble the washer and see if it will work properly.
If not, then you will need to replace the flood pressure switch. The
part number for the flood pressure switch is 8054767. You can order
this part from the
Sears PartsDirect website. The part number for the flood pressure switch is 8054767.
